please help...i need info fast
ok i just bought my 93 eg hatchback..the only down side is that its an automatic...i was going to wait to swap it to manual when i get my type r, but what i need to know now is this..next friday i am gettin a full gsr dash with itr cluster, all of the parts were from a manual integra..will the harness and everything hook up alright or will i have a problem....what do i need to do to make this work or will it work just fine...my hatch is a dx without a tach in the cluster...let me know what i need to do to make everything work...thanks
hey i have done this swap before its pretty easy as for the auto that doesn't matter theres a plug in the floor where the shifter is suppost to go and all the holes are there for the linkage just add a clutch pedal clutch master resevior and clutch line as for the harness the tach wires and everything are there in the harness but the integra cluster uses different plugs so either run a new integra harness or cut the cluster plugs off the eg harness and solder the integra ends on if you need any more help ill be watching this post or im me on aim pootsiracer is the s/n
sincerly Ryan of premomotorsports
ALLMOTORH22A
Apr 3, 2007 07:47 AM
