Clutch Torque specs SEARCHED
Pressure plate is 19ft lbs. can't remember the flywheel I beleive around 50. I never torque those though. When all else fails, tight is tight and too tight is loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">I never torque those though. When all else fails, tight is tight and too tight is loose.
Yeah, the correct torque spec is "#3 on the impact gun". Unless you're seriously ****, it's not worth the time to set the torque wrench and hold the flywheel. I'm moderately **** and I give it the impact.
</TD></TR></TABLE>Yeah, the correct torque spec is "#3 on the impact gun". Unless you're seriously ****, it's not worth the time to set the torque wrench and hold the flywheel. I'm moderately **** and I give it the impact.
trooper0641
Nov 29, 2004 03:10 PM
