Code 15?
I was driving along today and my car just died and wouldn't start back up. When it died the check engine light came on and so did the oil light. The ECU is throwing a code 15. I have recently changed the cap/coil/plug wires & plugs.
The manual says to remove the hazard fuse and try again but my car wont start. It tries but wont catch. Do I need to replace the ignitor?
BTW this is a 90 crx si.
Code 15 (15 flashes) Ignition output signal.
Code System
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
Code System
stocker2shocker91
Dec 13, 2006 04:17 PM
