H22a?
Old Oct 22, 2004 | 07:45 PM
DelSolKid's Avatar
Default H22a?
How does an JDM H22a compare to a B18C5 in Del Sol compatability and performance? I noticed the H only had 10 less horses, but almost 20 more tq, which is better, is the H a much harder swap on a sol, hit me up with info.
Thx
Old Oct 22, 2004 | 07:57 PM
hatchfreak92's Avatar
Default Re: H22a? (DelSolKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolKid &raquo;</TD></TR><TR><TD CLASS="quote"> I noticed the H only had 10 less horses, but almost 20 more tq, which is better, is the H a much harder swap on a sol, hit me up with info.
Thx</TD></TR></TABLE>
if im correct the h22 has more hp and tq but it is a little heavier than the b18c5. i think for a del sol the b series is much easier to drop in than a prelude engine.
Old Oct 22, 2004 | 08:02 PM
t0p_sh0tta's Avatar
Default Re: H22a? (hatchfreak92)
B series is a bolt-in affair.
H series will require chassis modifications.
Luserkid's Avatar
Stock for stock H22 will take a B18c(5) off the line, no doubt.
Now for top end and to finish the 1/4 mile the B18c(5) has the H22 beat.
Search theres plenty of H22 vs B18c(5) out there.
Old Oct 22, 2004 | 08:04 PM
nighttrain33's Avatar
If I'm not mistaken, the Teg type R has 195 hp, and the H22 has 200. But of course the H22 has more torque, like you said.
-Shane
Old Oct 22, 2004 | 08:10 PM
DelSolKid's Avatar
Default Re: H22a? (nighttrain33)
JDM B18 Type R has 210hp cause they run it at a higher compression ratio, USDM has 195, but I'm talkin strictly jdm on both ends, so comparison is 210hp/138tq for B18C5 versus 200hp/158tq for H22, but if the H requires chassis work and a whole disastrous ordeal such as that, forget it, I'll go type r any day.
Old Oct 22, 2004 | 08:22 PM
01-1293's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolKid &raquo;</TD></TR><TR><TD CLASS="quote">JDM B18 Type R has 210hp cause they run it at a higher compression ratio, USDM has 195, but I'm talkin strictly jdm on both ends, so comparison is 210hp/138tq for B18C5 versus 200hp/158tq for H22, but if the H requires chassis work and a whole disastrous ordeal such as that, forget it, I'll go type r any day.</TD></TR></TABLE>
your a dumb ***...the jdm type r has 200hp.....usdm 195.........
Old Oct 22, 2004 | 08:23 PM
h22John's Avatar
type-r would be your best bet, easier, much less of a headache, easy wiring easy mounts. H22 isnt THAT hard but alot more involving........as far as 1/4 mile performance, stock for stock and same chassis/ set-up, flip a coin. I autox my h22 hatch, handles GREAT btw!!!! I was only 1.6 seconds off a slicked z06 with a very good driver(alot better than me anyway)! Anyway IMO there are no cons with either setup. You'll be thouroughly satisfied with either. Have fun and good motoring to you .....................John
Old Oct 23, 2004 | 04:04 AM
94_HATCH's Avatar
Default Re: H22a? (h22John)
h22 swap is gonna be cheaper than the type r swap from MOST performance shops. That is what i based my h22 purchase on. Peformance wise your getting more torque with the h22. The type r engine has a higher redline if your looking for something you can rev up past 7200 rpm(stock h22 redline). All in all its up to you and your wallet
Old Oct 23, 2004 | 05:03 AM
97hatchback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchfreak92 &raquo;</TD></TR><TR><TD CLASS="quote">
if im correct the h22 has more hp and tq but it is a little heavier than the b18c5. i think for a del sol the b series is much easier to drop in than a prelude engine.</TD></TR></TABLE>yes you're correct the h22 does have more hp and tq, the b series would probably be the best swap
LowNSlowDelSol
Jan 15, 2013 09:16 AM
93_delsol_si_gsr
Nov 2, 2008 04:44 PM
eminemini7
Apr 18, 2005 10:14 AM
flippedoutasian
28
Nov 13, 2003 01:21 PM
flippedoutasian
Oct 12, 2003 06:55 PM
