CV BOOT REPLACMENT HELP
Old Oct 22, 2004 | 07:39 PM
jayr7309's Avatar
Default CV BOOT REPLACMENT HELP
CRACK CV OUTER BOOT
Ok I was wondering if anyone can help me, I just took out my driver side axle and I seperate the cv joint and that was e z after hitting on the ring with hammer, but now I put the new boot and found it hard as hell to connect the axle to the cv joint, theres this C-clip at the end of the post where it connects back to the CV joint. I guess its like a post lock.
It's so hard to get it flush while pushing it back inside the ball bearings, "CV JOINT" Hard to explain
Honda Civic 96 4dr sedan
non-Vtec Sohc
Modified by jayr7309 at 8:53 PM 10/22/2004
Old Oct 22, 2004 | 08:12 PM
Luserkid's Avatar
Default Re: CV BOOT REPLACMENT HELP (jayr7309)
Have fun. Just keep trying to push it in. It should go in, but i believe it only goes in one way. Then put the boot together. (of course your going to have the boot on while your trying to put it back in its slot )
Old Oct 22, 2004 | 08:19 PM
hatchi's Avatar
why not put something that will hold the clip down while you slide the outer portion in
Old Oct 22, 2004 | 08:32 PM
civicracer1600's Avatar
what you need to do is slide the joint onto the axle shaft up to the clip and then appy pressure onto the joint against the clip. Now take a flat blade screwdriver and push one side of the clip up under the joint. then apply pressure to the side of the joint where you pushed the clip in first. now take the screwdriver and push the other side in the best you can while holding pressure on the joint. then just smack it with a hammer and it will go right over the clip. good luck
Old Oct 22, 2004 | 09:10 PM
jayr7309's Avatar
THANKS, I think I just got buff trying this CV boot replacement
waid786
Apr 19, 2012 07:03 AM
Jimster480
Jan 22, 2010 10:58 AM
oldskoolDA6
Jul 9, 2009 11:39 AM
sohcef9
15
Oct 2, 2005 06:39 AM
TeginRAGE
Jul 17, 2001 06:17 AM
