How do you launch a k20a with LSD at the strip?
Sorry for the dumb and newbie question but do you have any tips?
I don't know if its my tires but I usually get some wheel spin launching it at 5k. How do you get more traction out of this?
Thanks!
Thanks!
**** 5k with lsd is abuot right what kinda 60 ft times u getting with that launch...ive seen a guy who i know pull 1.8 60 fts with street tires in a stock Intake and exhuast 99 si and run 15.4 thats launching at like 6k pretty crazy but it hooked most of the time cant think of the tires but street tires not drag radials or slicks and no lsd
lower ur tire pressure also mess with it to see what is best for u
try slipping the clutch at 5k, u just gotta go and try different things til u find what works... good luck with ur times
You guy's have it ALL WRONG!! Let me show you how to launch... write this down ok? ..
First start up the engine.
Second put it in first gear.
Thrid REV it up to 8500 RPM.(hold it for about 10sec. at 8500 RPM)
Forth release the CLUTCH.
DONE!!!
let me know how that goes?
OhH.. by the way, do you have extended warranty?
DONE!!!
2.2 is far from awesome but 2.2 is about as good as you can get on stock tires. of course you can't compare this to slicks or anything. on street tires, most ppl end up with not much better than 2.0-2.1's.
If your wheels spin, ride the clutch a little more before letting completely off... this is just a feel thing. Launch isn't as important as heel-toe/3-pedal anyway. LSD works better in the corners, not off a launch. Anything with a k20a should be racing thru corners anyway even though the power is very impressive.
