ITR @ headertest?!
Old Dec 19, 2001 | 05:06 AM
austrian type-R's Avatar
Default ITR @ headertest?!
Man, this ITR has 25whp more than mine had!
I had stock 151.5whp and this one make about 178whp? Comon guys, what is wrong here.
I know I have a weak one and mising 5-8whp, but we are talking of 25whp
Old Dec 19, 2001 | 05:08 AM
Xerzex's Avatar
New User
Default Re: ITR @ headertest?! (austrian ITR)
it might not be that far off. Look what I dyno'd at in my sig with just those mods.
Bbasso's Avatar
what else do you have done to the car?
Old Dec 19, 2001 | 05:12 AM
sackdz's Avatar
Remember it wasn't totally stock... It was with a Comptech Icebox, high-flow cat, and power steering removed..........
But I think the #'s are damn high too, Ryan you lucky sob
[Modified by sackdz, 9:13 AM 12/19/2001]
Old Dec 19, 2001 | 05:15 AM
Default Re: ITR @ headertest?! (sackdz)
Powerstearing removed, yeah, how much hp will that add? about 3whp? ...and the cat about 3whp..........the icebox another 5whp
5+3+3+8(adding to my weak engine)= 19whp okay...Iīm there and Iīve heard the 2000 and the 2001 models are a bit stronger, is that true?
Old Dec 19, 2001 | 05:19 AM
sackdz's Avatar
p/s i've seen charts from 3-5 whp. high-flow cat & intake together might be more than 6 whp, but fine call it 6. If your car is at the bottom end of the spectrum an his is at the top, I'd say that range could possibly be 15 whp.
There's 24-26whp... I don't think it's that hard to fathom.
Old Dec 19, 2001 | 05:22 AM
Dr Pooface's Avatar
My 01 ITR STOCK made 168/120 on a Dynojet. [EDIT] And Lotus made 170 STOCK. [/EDIT] The numbers of the ITR at the test seem right to me.
[Modified by Dr Pooface, 6:24 AM 12/19/2001]
Old Dec 19, 2001 | 05:23 AM
yakkosmurf's Avatar
151 is terrible for a Type R. Even the stock Celica GTS dynos higher than that. I'd give your car another run.
Old Dec 19, 2001 | 05:29 AM
Willard's Avatar
I would not be concerned with the actual numbers... just the changes that you get with your modfications.
You were on a different dyno..
Will
Old Dec 19, 2001 | 05:30 AM
TypeR 599's Avatar
Default Re: ITR @ headertest?! (yakkosmurf)
well my 98 only pulled 155whp dynojet. i have a aem cai and a 5zigen catback. that result sucks. i dont know whats wrong
Old Dec 19, 2001 | 05:43 AM
Default Re: ITR @ headertest?! (type R 599)
I know a guy from Germany, he has only 149whp stock! We are using Bosch dynos and DIN correction. Maybe there is the difference.
Old Dec 19, 2001 | 06:40 AM
sackdz's Avatar
Default Re: ITR @ headertest?! (George Knighton)
I thought we had determined that the 00/01 intake cam had slightly longer duration?
Old Dec 19, 2001 | 07:11 AM
SoCal ITR's Avatar
Elevation?
Old Dec 19, 2001 | 07:18 AM
CPR's Avatar
CPR
As someone else has already said...don't worry about the beginning figure. Every dyno is different, and every car is different.
I think the beginning figure does play a role in some circumstances. One valid case would be where 2 cars had the same mods and they dyno their car the same day to find out that there's a significant difference between the numbers. The question now then becomes, what is a significant difference.
Old Dec 19, 2001 | 07:42 AM
Default Re: ITR @ headertest?! (CPR)
elevation about 700 meters above sealevel where I do the dynoruns. I donīt know the elevation of the German dude, but I guess around 400-500
Old Dec 19, 2001 | 04:45 PM
S&P500ITR's Avatar
New User
His car is most definitely on the strong side! My 01' with JDM DC, test pipe, and stock intake w/cover removed only put down 164.3/122.6 on a dynojet (f'n weak. )
Dsee2
Aug 3, 2007 02:12 PM
thelobster
May 22, 2004 04:49 PM
Pompiuses
Jan 2, 2003 02:53 PM
Flux
Nov 18, 2002 08:17 AM
