what is ur RATING (1-10) for OMNI Front camber kit
well like the topic says...if any of have or had experienced OMNI camber kit..please let me know how much you like or dont like it...thanx guys
cuz im thinking of getting OMNI,,,,and they are replica of skunk2 right?
my cambers are -3 front left, -3.5 front right....pretty dann bad
thanks guys
thanks guys
i just installed mine yesterday, so i dont think i can give a very worthy opinion. but, ive heard lots of good things and mine seems good so far. except my stock cotter pins were too small and the kit i got didnt come with any, so we just bent the stock ones *shrugs*.
I have had these on my car for a few weeks now and I dunno if the skunk ones are like this but....
The bolts that are on the arm for the adjusting of the ball joint position are made if real cheap aluminum bolts that will snap if you over tighten them. I went and got stainless bolts to replace all of the ones on there.
All in all, I guess its an ok set up but seemed like more trouble than it was worth when i snapped that bolt.
Mine are the Skunks but the Omnipower ones are the same. I give them a 2 out of 10. Negative points for inadequate hardware and fitment.
https://honda-tech.com/zero...age=1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Mine are the Skunks but the Omnipower ones are the same. I give them a 2 out of 10. Negative points for inadequate hardware and fitment.
dann are you for real...****...2 is hella bad of too bad
well James sorry to heard....but i broke my control armm of my front driver's side once...scary as hell...
anyone have else can give me more info about OMNI
i found out last night that my kit was supposed to come with crown nuts and cotter pins but didnt. but the guy is cool and is going to send them to me. hope i dont eff up my car. dont think i will, calm driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 »</TD></TR><TR><TD CLASS="quote">i give them 8/10..working very nice for me..and you gave them negative points for what inadequate hardware?</TD></TR></TABLE>
Do a search on the Skunk 2 arms and you'll find that many people have had problems with them slipping. Star washers are need to bite into the steel so they don't slip and the hex head give a bit more clearance on top of the arm, easier to fit a wrench in there too. Skunk 2 has redesigned their mounting system with a plate ontop... negatives of this system is that it's hard to get to the adjusting screws since they're on the bottom now.
Also the interference with the frame is a negative, there should be adequate clearance. Your milage may vary.
They're working for me now but for $160 I expect them to fit and perform from the start.
even though they look the same the skunk2 and omnipower are different. ask steve from omnipower. he said that they are the same casting in pieces but he welds them differently than skunk2.
Carlo
Carlo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laezpnai »</TD></TR><TR><TD CLASS="quote">i found out last night that my kit was supposed to come with crown nuts and cotter pins but didnt. but the guy is cool and is going to send them to me. hope i dont eff up my car. dont think i will, calm driver.</TD></TR></TABLE> LOL, what the heck is "cool" about sending you parts that were supposed to be included in the first place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laezpnai »</TD></TR><TR><TD CLASS="quote">at least he wasnt a dick and didnt respond or "suddenly disappear", you know... </TD></TR></TABLE> Are you sure you need a camber kit w/ eibach sportlines? Even w/ a 2.25 drop in the rear my rear camber was fine, just the front was out of spec.
why not? id probably end up needing it eventually anyway. ive already paid for it and installed it, so.....
and i didnt say it was cool that the guy didnt send me everything, i said the guy was cool..
kick back
kick back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 »</TD></TR><TR><TD CLASS="quote">I have the old Skunk 2 ones, and I have never had any problems with them. they have never slipped at all. Been using them for almost a year now too.</TD></TR></TABLE>
Many canyon runs later I too have never had a slippage problem. I own the new skunk ones along with many of my friends. Ask people who own skunk2 and 9 out of 10 will not have a slippage problem.
I've got the Omni's. Put them in a couple of days ago. Went in fine, but they rub against the frame. Pain in the ***. Now I gotta take them out and file them with a die grinder.
Oh well.
Oh well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg »</TD></TR><TR><TD CLASS="quote">I've got the Omni's. Put them in a couple of days ago. Went in fine, but they rub against the frame. Pain in the ***. Now I gotta take them out and file them with a die grinder.
Oh well.</TD></TR></TABLE>
dann lot of negative ...rub against the frame is hella bad...slip off is worse but fixable....should i give it a try for OMNI
for rubbing against frame is hella obvious by visually ...the ball join is about 1/2 inch longer than stock i think...
the guy going for $145 for fronts? how does that sound?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laezpnai »</TD></TR><TR><TD CLASS="quote">why not? id probably end up needing it eventually anyway. ive already paid for it and installed it, so.....
kick back
</TD></TR></TABLE> ? I am kickback...I just dont understand why someone would get a product they didnt need and install it....
Well, I have a jdm front end so I guess I answered my own question!
on me. I have ingalls front camber kit and it corrected my camber perfectly, no problems w/ the kit for about 2 years now.
kick back
Mine are on the table, just got here yesterday and I have to say I wish I would have caught this thread sooner. This comment alone
Makes me wish I hadn't got them, but WTH. Stuck withem now I guess.
If your product doesn't fit/work like it should...it should at least be cheap.
Oh, and I got crown nuts but no cotter pins
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster »</TD></TR><TR><TD CLASS="quote"> Oh, and I got crown nuts but no cotter pins
gheeeeey
*still need to email the guy back*
drove my car today, alignment is all whacked out.. blah blah blah.
btw, my car dropped 2-2.5.
AND i think mine is rubbing tOo.
</TD></TR></TABLE>gheeeeey
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster »</TD></TR><TR><TD CLASS="quote">Mine are on the table, just got here yesterday and I have to say I wish I would have caught this thread sooner. This comment alone
</TD></TR></TABLE> wow. I cant wait to see what the omnipower bandwagon has in reply to all these complaints. :grabs popcorn, takes a seat:
