from regular to synthetic
Old Oct 22, 2004 | 04:38 PM
quazar's Avatar
Default from regular to synthetic
I was told that when you switch from regular oil to synthetic you should do another oil change soon because of the synthetic oil breaking up the old sludge. How many miles do you think I should make that next oil change? thanks.
Old Oct 22, 2004 | 04:42 PM
Kyles ej1's Avatar
Default Re: from regular to synthetic (quazar)
i didnt and mine was fine
Old Oct 22, 2004 | 04:44 PM
foureightMOTORSPORTS's Avatar
I didn't either. Mine is ok.
Old Oct 22, 2004 | 04:46 PM
SOHC4life 96's Avatar
Default Re: (foureightMOTORSPORTS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i didnt and mine was fine</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foureightMOTORSPORTS &raquo;</TD></TR><TR><TD CLASS="quote">I didn't either. Mine is ok. </TD></TR></TABLE>
Same here. You could do it and tell us how it goes.
Old Oct 22, 2004 | 05:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">Same here. You could do it and tell us how it goes. </TD></TR></TABLE>
Or you can stick with the dino-juice like me.
Old Oct 22, 2004 | 05:04 PM
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Or you can stick with the dino-juice like me. </TD></TR></TABLE>
I'm going to be switching from full synthetic to synthetic blend next oil change.
Old Oct 22, 2004 | 06:25 PM
quazar's Avatar
why?
nighttrain33's Avatar
The only thing with going to synthetic from regular is that sometimes the seals leak if they are bad because of the makeup of the synthetic oil.
-Shane
Old Oct 22, 2004 | 06:32 PM
Default Re: from regular to synthetic (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quazar &raquo;</TD></TR><TR><TD CLASS="quote">why?</TD></TR></TABLE>
Me? For one it's cheaper. And I will be going tubo soon also.
Old Oct 22, 2004 | 06:39 PM
quazar's Avatar
I heard the seals leak when you go from syn to regular, not the other way
Old Oct 22, 2004 | 06:41 PM
hondainspired's Avatar
Default Re: from regular to synthetic (DOHC4life)
ok... owned a 89 prelude si that i burnt all the seals up on and rings and whole nine yards.... from going from royal purple back to my castrol ( cause it was rediculous for me to be spending 8 per QT.)
Old Oct 23, 2004 | 05:50 AM
EK45VTi's Avatar
Default Re: from regular to synthetic (hondainspired)
You don't have to change the oil soon if you are not **** about your car...
But if you can afford it, why not... but my point of view is that you don't have to change your oil filter at first (cos it is the waste of money) but it is at your own risk...
Just drain the old oil... put in some synthetic that you will use further on...
Run it for 800-1000 miles but do not floor your car... just drive it carefuly...
Then after 1000 miles drain that oil, replace the oil filter and put in new oil... you should be fine...
But like guys above said, it is not necessary as long as you change your oil regularly (3000-3500 miles including oil filter every time)...
s2k5
Honda S2000
21
Sep 22, 2007 08:44 PM
axionm1k
Sep 24, 2006 06:20 PM
Hwj_33
Sep 1, 2006 09:32 AM
scrap1ngsr
Jun 6, 2003 06:25 PM
oryanh
Apr 22, 2003 08:04 AM
