Coupe makes Squeeky Noise evertime I Hit a Bump. ????
Old Oct 22, 2004 | 11:54 AM
2Point2EH2's Avatar
Default Coupe makes Squeeky Noise evertime I Hit a Bump. ????
Dont know what to search under?, But everytime I hit a bump since we lowered it, you can hear a squeeky noise coming from somewhere around the shocks.. . Its a 98 coupe witha 3 inch drop all around? And the back is cambering like a ****... Waiting on a camber kit.. What do ya'll think it might be? Shocks,...ect.?
Old Oct 22, 2004 | 05:48 PM
robbieshonda's Avatar
Default Re: Coupe makes Squeeky Noise evertime I Hit a Bump. ???? (EgHatchE)
grease your nipples.. No really find the nipples and grease them everyonce and a while it helps the suspension move freely
Old Oct 22, 2004 | 05:50 PM
eL's Avatar
eL
my coupe squeaks too... i think its the camber kit though.
nipples? explain, sounds interesting
Old Oct 22, 2004 | 05:52 PM
SOHC4life 96's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">my coupe squeaks too... i think its the camber kit though.
nipples? explain, sounds interesting </TD></TR></TABLE>
Mine does too. But it did before I lowered it with springs too. *scratchs chin* I dunno. Lets here about these nipples, that could be my problem too.
j_ambrose's Avatar
Mine does it too, I just figured all the shocks were blown.
Old Oct 22, 2004 | 05:56 PM
blueeg's Avatar
Default Re: (ElJefe982)
nipples? are u talking about the zerg fitting. if so, civic dont have them. you dont need to lube the suspension. my civic makes a squeak noise everytime i go over a bump too. time for new shocks.
Old Oct 22, 2004 | 05:59 PM
eL's Avatar
eL
yeah, i too could use new shocks.
Old Oct 22, 2004 | 06:02 PM
BlueIntegraBoy's Avatar
Default Re: (eL)
I dont think its the shocks. My friend's Civic was doing it and we replaced the shocks with Tokico HPs and it still squeeks over bumps.
Old Oct 22, 2004 | 06:17 PM
bgoetz's Avatar
the bigest problem i have with mine is the damn plastic stock dust boots that the directions told me to put back on the rear shocks fighting with springs. It sounds awful like a pop can crushing and then I have to cut off the portion that got fucked up so it does not fight with the spring anymore
Old Oct 22, 2004 | 10:28 PM
2Point2EH2's Avatar
Default Re: Coupe makes Squeeky Noise evertime I Hit a Bump. ???? (bgoetz)
In the back, it cambers alot, but I seriously dont think the shocks are bad? I think I need a camber kit.. Forgot to mentinion... When I jacked up the back to see if somethin was loose or something, I looked at the coilover sleeve and like the spring is rubbing againt it. .?? You think that might be it?
Old Oct 23, 2004 | 11:23 AM
2Point2EH2's Avatar
Bump... Anybody else???
Old Oct 23, 2004 | 12:58 PM
oreozzz's Avatar
check the balljoints...i had that problem
Old Oct 23, 2004 | 06:14 PM
Default Re: Coupe makes Squeeky Noise evertime I Hit a Bump. ???? (oreozzz)
Wouldn't be the balljoints for my friend since the squeeking is coming from the rear.
Old Oct 24, 2004 | 11:26 AM
2Point2EH2's Avatar
Default Re: Coupe makes Squeeky Noise evertime I Hit a Bump. ???? (BlueIntegraBoy)
I mainly here it on the passenger side, front and back....?
lowtoys
Jun 18, 2008 04:41 PM
EJ8 GSR-T
Aug 4, 2005 10:07 AM
d16why
18
Oct 5, 2003 09:26 AM
-slow ej-
10
Jun 4, 2003 08:42 PM
jojopolo
Oct 8, 2002 12:29 PM
