sunroof sounds bad when closing
Old Oct 22, 2004 | 11:05 AM
kriptik's Avatar
Default sunroof sounds bad when closing
anybody encounter a problem with their sunroofs? Mine makes a shutter or flutter noise really loud when it closes on the back part, where it goes down at the back. Is this a recall issue or wut does n e body know about this?
Old Oct 22, 2004 | 11:09 AM
Paul H22A4's Avatar
Default Re: sunroof sounds bad when closing (kriptik)
Try lubing up the railing.
Old Oct 22, 2004 | 11:14 AM
nbwh22's Avatar
yea mine used to get stuck closed but i cleaned the tracks and sprayed some wd40 on it and it was good asnew!
Old Oct 22, 2004 | 03:13 PM
99GreenLude's Avatar
Default Re: (nbwh22)
Clean out the tracks and use tons of WD40 on the new tracking. This worked for mine as well as what nbwh22 stated.
Old Oct 22, 2004 | 08:58 PM
limpmode's Avatar
Default Re: (99GreenLude)
WD40 will work short term, but you want to use a good grease on it, WD40 is just for water displacement. mine did it too, grease it up good.
Old Oct 22, 2004 | 09:16 PM
OxYi's Avatar
Default Re: (limpmode)
ahh yea mine makes noise as well, going to try ur method tomorrow
what about the driver windows ? it makes noise for me too .. any way to fix that ?
Old Oct 23, 2004 | 05:35 AM
Superstorm's Avatar
Default Re: (OxYi)
Take the door panel off and check the tracks also. They make oil or lube for that kind of stuff too.
Old Oct 23, 2004 | 10:08 AM
UA6 BALLER STATUS's Avatar
Default Re: (Superstorm)
When its very cold at night my sunroof opens very slowy and when its warm outside it opens normal. Does Honda make some kind of Oil for the sunroof?
Old Oct 23, 2004 | 10:17 AM
fastprelude60657's Avatar
mine used to do the same thing, i used white litheum grease and its fast as hell now !!very smooth
Old Oct 23, 2004 | 12:41 PM
red92si's Avatar
I clean my tracks every couple months and make sure to lube them up with white lithium grease. Works like magic
Old Oct 26, 2004 | 10:39 AM
kriptik's Avatar
Default Re: (red92si)
yup some heavey duty valvoline lube spray did the job, thanks guy!!
Old Oct 26, 2004 | 10:51 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (kriptik)
Yup, silicone spray, lithium grease should work fine for the sunroof.
As for the windows, it should work too. But if the window shudders going up and down, it's the window regulators.
I had mines replaced under warranty when I had the lude.
alldemtingz
10
Mar 23, 2009 02:59 PM
Uberfit
Mar 18, 2009 07:44 PM
wxy117
Mar 24, 2008 10:26 PM
93preludeh22
Dec 12, 2004 07:36 AM
Crackerballer
Jan 8, 2004 07:14 AM
