Puting integra seats in a EG
Old Oct 22, 2004 | 10:12 AM
HONDA92HATCH's Avatar
Default Puting integra seats in a EG
My integra seats won't fit in my 92 hatch A couple of my friends have just fit theres right in without tradeing rails or anything but theres were out of a 95 and down only 2 blot holes line up on mine would my rails fit on integra seats??thanks
Old Oct 22, 2004 | 10:17 AM
Timmay's Avatar
Default Re: Puting integra seats in a EG (HONDA92HATCH)
hmm i have 99 integra cloth seats in my 93 lx, i got all 4 bolts in, they do sit a tad crooked though
Old Oct 22, 2004 | 10:20 AM
FERIOkid's Avatar
Default Re: Puting integra seats in a EG (Timmay)
i have integra gsr leather in my 93dx sedan and they fit perfect. My friend had them in his hatchback before me and nonw he has ITR seats
Old Oct 22, 2004 | 10:22 AM
HyBriDcxR's Avatar
It should fit. I didn't swap the rails on mine.
Keep the two that you have in loose and move the seats around a bit and you should get all four to line up.
Old Oct 22, 2004 | 10:27 AM
slim's Avatar
New User
yes the rails swap over. I just put 95 seats in my 92 hatch. I had to swap rails because the previous owner had them in a datson and modded the integra rails. Mine sit straight too.
Old Oct 22, 2004 | 10:41 AM
iBear's Avatar
Default Re: (slim)
yeah, just move the seats around a little bit, it should fit. If not, just swap rails
Old Oct 22, 2004 | 11:09 AM
eg92b16a2's Avatar
Default Re: (EJellyfish1)
depends on what year the teg seats are from.. if they are the older ones the passenger will fit right in but the driver one will need to be swapped out..
Old Oct 22, 2004 | 11:46 AM
hypa's Avatar
Default Re: (eg92b16a2)
I fit ITR seats in an EG with no real issues. The ITR seats needed a stud welded to the chassis in order to mate with the rear/outer bolt in the back of the seat. Once that was done, all it took was a few washers to space it all properly, and BAM itr seats in an EG.
GSR seats bolted in no problem at all.
Using washers, we were able to set them straight.
Old Oct 22, 2004 | 03:27 PM
Tyree's Avatar
Default Re: (hypa)
I put 97 Gsr lether seats in my 92 EG. I swapped the rails because one of the bolts on each side were to short, it sits perfect
Old Oct 22, 2004 | 03:56 PM
Braco11's Avatar
Default Re: (Tyree)
when i had to take my seats out one time i messed up the rail alignment by pulling on the lever that allows you to slide the seat forwards and backwards. try that.
marcos09
Dec 26, 2009 12:22 PM
konidude
Oct 1, 2005 08:09 PM
jdmcr-x1990
Aug 20, 2005 12:11 PM
foz
Jan 15, 2004 05:53 PM
DV98CVC
Nov 25, 2002 05:06 PM
