EGR Valve Bypass
Old Oct 22, 2004 | 09:59 AM
zCivic's Avatar
Default EGR Valve Bypass
Ok I'm running a CX engine in my 89 CRX with a PM8 ECU. I had a 89 TEG ECU PG7 and it was too rich. I have a code 12 which is for the EGR valve. Problem is I dont have any EGR valve in/on the engine/chassis. Is there anyway to trick the ECU into thinking the EGR is working or can I add an EGR some how to the chassis/engine.
TIA
Old Oct 22, 2004 | 03:50 PM
DC-4-Drew's Avatar
Default Re: EGR Valve Bypass (zCivic)
I wrap everything in duct tape.......Including the blinky light on the ECU, that gets rid of the code....If you will take a screwdriver and poke out the check engine light you won't have to worry about that either...hope this helps.....JK Holla
Old Oct 23, 2004 | 12:00 AM
drussell4801's Avatar
Default Re: EGR Valve Bypass (b16a3delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol &raquo;</TD></TR><TR><TD CLASS="quote">I wrap everything in duct tape.......Including the blinky light on the ECU, that gets rid of the code....If you will take a screwdriver and poke out the check engine light you won't have to worry about that either...hope this helps.....JK Holla
haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">Ok I'm running a CX engine in my 89 CRX with a PM8 ECU. I had a 89 TEG ECU PG7 and it was too rich. I have a code 12 which is for the EGR valve. Problem is I dont have any EGR valve in/on the engine/chassis. Is there anyway to trick the ECU into thinking the EGR is working or can I add an EGR some how to the chassis/engine.
TIA</TD></TR></TABLE>
How does the ECU know that the EGR is working on Hondas?
Figure that out and there's your answer.
97_dc2
Apr 13, 2007 07:36 AM
sublimenerd
Oct 19, 2006 09:11 PM
genpix
11
Oct 30, 2004 04:21 PM
Chris_Bye
Jul 10, 2004 12:10 PM
mugen-man
Aug 28, 2003 07:12 PM
