Wondering what the best aftermarket radiator is to get for a ek civic
The Auto EX/Del Sol OEM Dual Core radiator. I'd be more than willing to bet you can't overheat your car with one of these.
get a dual core unless you need room for a turbo, then get an ebay single core. either way, best and inexpensive shouldnt be used together.... it's misleading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedie »</TD></TR><TR><TD CLASS="quote">i want a preformance like a fluidyne or something</TD></TR></TABLE>
Are you not understanding what we're saying here. A Fluidyne radiator is a huge waste of money. Best bang for the buck is the dual core Del Sol/Automatic EX radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedie »</TD></TR><TR><TD CLASS="quote">stock , but i want a performance one like fluidyne</TD></TR></TABLE>
Goddamnit, I swear....
Some people just don't listen. Why would you need a performance radiator? Because your having problems with overheating based on the radiator. Why would you be willing to pay 300+ dollars for a bling peice like a Fluidyne radiator when the one that I've already told you was the best for the money (which is less than 100 dollars by the way) will be more than enough cooling.
How much does a NEW dual core Del Sol radiator cost?? I know they aren't cheap and do they still use the plastic caps on the top and bottom?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 »</TD></TR><TR><TD CLASS="quote">How much does a NEW dual core Del Sol radiator cost?? I know they aren't cheap and do they still use the plastic caps on the top and bottom? </TD></TR></TABLE>
http://cgi.ebay.com/ebaymotors...33602
if u really want to spend the money... try out
http://www.coolradiator.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 »</TD></TR><TR><TD CLASS="quote">So your saying they are better than OEM radiators??</TD></TR></TABLE>
It's a radiator. A case with some endtanks and fins. Radiatorbarn or something like that sells them on Ebay all day long. These are OEM replacements. However, I'm not willing to pay whatever outrageous prices Honda is asking, so I look to these.
i was gonna post askin about aftermarket rads/ are they wort it/bettetr than oem and came across this thread.
got my answer, looks like ill be gettin 1 of ebay if i do need replacement in future.
you guys think honda takes the ****, you wanna come to u.k to check honda dealer prices
You think those ones off ebay are better than OEM, think again! I've seen my fair share of cheap radiators and I can tell you they are going to look like straight **** in a year or two. Good luck though.
My buddy has a built, 12.7 : 1 CR JDM B18C in his EG. He made the mistake of dropping $360 on a Fluidyne radiator. I only say mistake because the car usually won't heat up for thirty or forty minutes because the radiator is that good at shedding heat. Outstanding radiator, but more problems than it's worth.
