Exedy Clutch Kit Combo - Unheard of prices! Exedy Organic Clutch and our Pro Street Aluminum flywhe
Pro Street Online offers you our new Pro Street Clutch and Flywheel combos! We combine our Pro Street 8lb lightweight racing flywheels with Exedy's stage 1 organic clutch kits to bring you the best deal around!
When replacing your clutch, you MUST have your old flywheel either resurfaced or replaced to ensure proper contact and even wear during break-in. Your flywheel must be resurfaced by a machine shop to your applications specs. This resurfacing process can cost anywhere from 80-100 dollars when properly done. Why resurface your old flywheel, when you can replace it and upgrade at the same time! For just a little bit more, you can have a SFI approved lightweight flywheel to go with your clutch when its time to replace it.
Save by purchasing both items together!
Click here to order: Clutch and Flywheel Combo
In stock and ready to ship!
The driveability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All of these clutch discs have high capacity spring center dampers to reduce the drive train shock and impact.
Pro Street Lighweight Aluminum Flywheel Specs:
Super lighter weight equals faster acceleration.
Reduce turbo lag.
Gain more mid-range for ALL MOTOR engines.
6061-T6 aircraft grade billet aluminum.
Billet Aluminum Flywheels meet SFI Spec 1.1 or 1.2
Weights 8lbs
Acura CL 1997 PSCB02 $409.99 Trim: 2.2L F22B1 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Acura Integra 1990 - 1991 PSCB07 $429.99 Trim: B18A1 Specs: Exedy Organic Clutch (08804) and Pro Street 8lb Flywheel
Acura Integra 1992 - 1993 PSCB08 $429.99 Trim: B17A / B18A Specs: Exedy Organic Clutch (08800A) and Pro Street 8lb Flywheel
Acura Integra 1994 - 2001 PSCB01 $399.99 Trim: B Series Specs: Exedy Organic Clutch (08800B) and Pro Street 8lb Flywheel
Honda Accord 1990 - 1997 PSCB02 $409.99 Trim: 2.2L F22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Accord 1990 - 2002 PSCB02 $409.99 Trim: 2.3L F22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Civic 1988 PSCB04 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda Civic 1988 PSCB04 $399.99 Trim: 1.5L D15 Wagon Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda Civic 1989 PSCB05 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08803) and Pro Street 8lb Flywheel
Honda Civic 1989 PSCB05 $399.99 Trim: 1.5L D15 Wagon Specs: Exedy Organic Clutch (08803) and Pro Street 8lb Flywheel
Honda Civic 1990 - 1991 PSCB06 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Civic 1990 - 1991 PSCB06 $399.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Civic 1990 - 1991 PSCB06 $399.99 Trim: 1.5L D15 Wagon Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Civic 1992 - 1995 PSCB03 $394.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Civic 1992 - 2000 PSCB03 $394.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Civic 1999 - 2000 PSCB01 $399.99 Trim: Si B Series Specs: Exedy Organic Clutch (08800B) and Pro Street 8lb Flywheel
Honda Civic 2001 - 2004 PSCB03 $394.99 Trim: 1.7L D17 Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda CRX 1988 PSCB04 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda CRX 1988 PSCB04 $399.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08802) and Pro Street 8lb Flywheel
Honda CRX 1990 - 1991 PSCB06 $399.99 Trim: 1.5L D15 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda CRX 1990 - 1991 PSCB06 $399.99 Trim: 1.6L D16 Specs: Exedy Organic Clutch (08801b) and Pro Street 8lb Flywheel
Honda Del Sol 1993 - 1995 PSCB03 $394.99 Trim: D15/D16 1.5 or 1.6L Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Del Sol 1994 - 1997 PSCB01 $399.99 Trim: B Series Specs: Exedy Organic Clutch (08800B) and Pro Street 8lb Flywheel
Honda Del Sol 1996 - 1997 PSCB03 $394.99 Trim: D16 1.6L Specs: Exedy Organic Clutch (08801A) and Pro Street 8lb Flywheel
Honda Prelude 1991 - 2001 PSCB02 $409.99 Trim: 2.2L F22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Prelude 1991 - 2001 PSCB02 $409.99 Trim: 2.2L H22 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Honda Prelude 1992 - 1996 PSCB02 $409.99 Trim: 2.3L H23 Specs: Exedy Organic Clutch (08805) and Pro Street 8lb Flywheel
Modified by prostreetonline at 10:04 PM 11/8/2004
Can you change the flywheel for a streetlite one
As I am not that keen on a 8lb flywheel for my Turbo'd 95 Integra B18C
And am I right in saying the streetlite is chromoly while the prolite is alluminum.
What would the price be please - also do you ship internationally
Who do you use?
Thanks
Who do you use?
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y B NA »</TD></TR><TR><TD CLASS="quote">Can you change the flywheel for a streetlite one
Who do you use?
Thanks
Sent you a PM.
Who do you use?
Thanks
Sent you a PM.
What clutch kit would you recommand for a turbocharged B16A2 aiming for ~300-350whp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">Will this hold 230-250 lb/ft of torque and 250+ whp on a boosted Sohc?
thanks
I would recommend the ACT Heavy Duty for you. We have a clutch kit combo with that here:
http://www.prostreetonline.com...combo
Hope this helps, let me know if you have any other questions
thanks
Thanks but im afraid the pedal with that ACT would bee too hard for my liking..So it seems ill stick with the Clutchmasters stage 3 and ACT light flywheel idea...
Ill get back to you later on that.
thanks
thanks
Interested in a clutch kit... I already have a flywheel, I just need to replace my clutch. I am looking for something that will take some abuse but I am happy/satisfied with my OEM clutch performance. By the way I will need this for my "stock" D16y7. What would you recomend and what kind of Unheard of price can you hook me up with?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">Interested in a clutch kit... I already have a flywheel, I just need to replace my clutch. I am looking for something that will take some abuse but I am happy/satisfied with my OEM clutch performance. By the way I will need this for my "stock" D16y7. What would you recomend and what kind of Unheard of price can you hook me up with?
Thanks
Sent you a PM
Thanks
</TD></TR></TABLE>Sent you a PM
I have a SOHC 1.6L D16Z6, Its mostly Stock But I want to boost it soon. What Kit would you recommend for me? I'd like something that I won't have to upgrade again when I boost. It is a daily driver so I need street drivability.
Thanks a bunch
-Joe
Thanks a bunch
-Joe
If you are not expecting much HP over stock, I would get the Exedy organic... otherwise, definately an ACT Heavy Duty.
Thanks!
Thanks!
I can vouch for the organic clutch in turbo applications. On my turbo b18c I make 270 to the wheels with the organic clutch matched with the stock flywheel. No slipping issues what so ever. Running strong turboed for over 8 months. pre turbo for 9 months no issues.
how much for the exedy stage 1 racing clutch 08801A model. i already have a flywheel, don't need the combo
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l337hxr »</TD></TR><TR><TD CLASS="quote">how much for the exedy stage 1 racing clutch 08801A model. i already have a flywheel, don't need the combo
thanks.</TD></TR></TABLE>
$246 with free shipping. In stock, and will ship today!
Thanks!
You can order here: Exedy Organic Clutch
Thanks!
