I need Help on 98 Vtec Prelude
Old Oct 22, 2004 | 06:43 AM
98Preluder7's Avatar
Default I need Help on 98 Vtec Prelude
I just recently done a head job to get everything back to stock. I had supposedly 8 bent intake valves. I believe the previous owner of the car never changed the timing belt and believe it may have skipped like 4 teeths on the cam gears. I replaced all the valves and sanded down the head so it was flush. I have full compression on all my cylinders now but the only problem is I feel that I am slower than what I use to run with the bent valves. I had bad compression with the bent valves they were all scattered : 160, 148 , 140, 120. I now have full compression of 185, 185, 185,185 all the way across. To me I believe I should be running a lot harder but I am not. I think maybe my vacuum hoses may have been not connected right but I checked them and it seems to be in order. I don't understand what else could be the problem. If anyone has an idea on what the problem could be please tell me.
Old Oct 22, 2004 | 12:56 PM
Paul H22A4's Avatar
Default Re: I need Help on 98 Vtec Prelude (98Preluder7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">To me I believe I should be running a lot harder but I am not.</TD></TR></TABLE>
Can you elaborate on this? What exactly is happening..
Old Oct 22, 2004 | 01:12 PM
98TypeSH's Avatar
Default Re: I need Help on 98 Vtec Prelude (Paul H22A4)
did ya put 91 octane in the tank? that will make your car feel slugish as a ****.
Old Oct 26, 2004 | 09:40 PM
Lets just say that a nearly stock CRX Si is keeping up with me and Its kinda of embarassing.
b18-crx
Apr 22, 2009 08:16 AM
Layziejoe775
Aug 26, 2006 03:54 PM
( o )( o )
Jul 3, 2006 06:17 AM
leeminho86
May 18, 2006 08:14 AM
NeVeR bLoWn
Oct 20, 2003 02:29 PM
