Vacuum Manifold and Brake Booster Check Valve
Old Oct 22, 2004 | 05:42 AM
aalb1's Avatar
Default Vacuum Manifold and Brake Booster Check Valve
I just realized that I tapped my Vaccum Manifold after the check valve on the brake booster line. My boost guage would steadily rise up to 7spi then slowly creep down into vacuum.
My question is this:
With the check vavle wasI even boosting 7psi or or was I boosting even more than that? If so then how much more?
Old Oct 22, 2004 | 06:51 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Vacuum Manifold and Brake Booster Check Valve (aalb1)
Well for some reason it sounds like your check valve is not working that well
As far as I know it is not supposed to allow ANY press to pass it so.....
I have never actually tested it so I really don’t know if its working or not??
I do know that there is no way to tell what you were boosting for 100% sure.
If I had to guess...Say....7lbs What is your W/G spring rating?
Old Oct 22, 2004 | 07:04 AM
RyanEJ8's Avatar
Check valve shouldn't let any boost by.
Old Oct 22, 2004 | 07:06 AM
aalb1's Avatar
Default Re: Vacuum Manifold and Brake Booster Check Valve (si2die4)
I have a 7psi WG spring. but that's hooked up to the Vacuum Manifold too. Well I guess I need a new check valve. About how much do they cost?
cheeesboiger
Jun 20, 2011 09:30 AM
lurkin' eg
Oct 19, 2008 04:28 AM
em1 Ziggy
Apr 17, 2006 04:08 AM
InLimbo87
Jul 26, 2004 05:49 AM
B18EG6
Aug 27, 2003 02:52 PM
