Caliper troubles
Old Oct 22, 2004 | 01:09 AM
96lewd's Avatar
Default Caliper troubles
I started the journey that i will call "replacing my brakes". I replaced the front rotors and pads in no time, it was easy. however when i got to the back i got everything on, but my piston wont go back. it wont move at all. i figured that it just had a lot of pressure, but it seriously wont move at all. i have tried everything that i can think of. has anyone else had this problem? do you have any ideas?? do i need to buy a new caliper?? if it is siezed as i think it might be, what can i do to un-sieze it? thanks a ton!
Old Oct 22, 2004 | 01:44 AM
TimeRacer's Avatar
Default Re: Caliper troubles (96lewd)
This is where having your manual out helps. You need to turn the rear piston in.
Old Oct 22, 2004 | 02:01 AM
britishlude's Avatar
If you clean up the piston and round the seals with brake cleaner this reduces chance of damaging the seal, you will notice some slots in the piston you can use a wide flat screwdriver or similar and just <U>TURN</U> the pistons back in, don't keep pressing them or you could damage them.
Old Oct 22, 2004 | 08:58 AM
Elkins911's Avatar
Default Re: Caliper troubles (britishlude)
damn hondas and their special tools
Old Oct 22, 2004 | 10:43 AM
Default Re: Caliper troubles (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">damn hondas and their special tools</TD></TR></TABLE>
LOL Yeah Honda caliper turner inners and Honda brake cleaner
Old Oct 22, 2004 | 01:37 PM
96lewd's Avatar
ok, so now i know what to do. thanks a lot. however while i was writting that first post my friend, or rather now, so-called friend pushed the brake pedal. the piston is now like an inch out and the boot around it doesnt even cover it anymore. i tried the twisting on that one but it just looks like it is spinning in circles. is there a trick to get it to go back in, or do i have to take the caliper apart now?? thanks again, the other back piston went in fine.
Old Oct 22, 2004 | 04:20 PM
Prolink's Avatar
You need to get new calipers or a rebuild kit.....
colinfindlay
Suspension & Brakes
Jan 29, 2013 11:15 AM
PJJ
May 13, 2007 01:01 PM
Catscan
Jun 12, 2006 09:38 AM
SKDRCR
Jan 18, 2004 05:18 PM
wickedxbo1
Dec 30, 2001 07:51 PM
