13 inch weld (wheels), Pros needed
Old Oct 21, 2004 | 09:32 PM
Quitripin's Avatar
Default 13 inch weld (wheels), Pros needed
I recently purchased some wheels for my gsr and i would like to know what size tire (slicks) would be the most effective on my 95 gsr (teg). Yes i have did some search but didn't not come up with the information i'm looking for. Asking the pros what will be best for my car. (all motor high compression set up)
thanks
B
Old Oct 21, 2004 | 10:45 PM
Street Ghost's Avatar
Default Re: 13 inch weld (wheels), Pros needed (Quitripin)
What times are you running right now?
Old Oct 22, 2004 | 08:54 PM
b18c195's Avatar
Default Re: 13 inch weld (_Project EJOne)
I just orderd weld too 13x8
this is the tire size i was going to use 24.5x8.5x13
Quitripin do you need spacers with those. if ya what size
thanks
Old Oct 23, 2004 | 07:06 AM
jdm_ef9's Avatar
Default Re: 13 inch weld (b18c195)
whats your setup? final drive? transmission?
im runnin weld draglites 13x8 w/ m-t 22x8x13 slicks. i have a 4.40fd.
i have to run spacers only because i have integra brakes.
Old Oct 23, 2004 | 10:16 AM
Zubaltec's Avatar
Default Re: 13 inch weld (jdm_ef9)
You would be suprised what a taller (then a 22") tire would do.
Old Oct 23, 2004 | 11:21 AM
Quitripin's Avatar
Default Re: 13 inch weld (Zubaltec)
Heres the run down i did with my all motor set up jdm_ef9
95teg interior strip
Engine b18c1 GSR
Quarter inch Deck plate (golden eagle)
Golden eagle Ductile Iron Sleeves
Pistons 85m Arias compression ratio is 12.5.1
Eagle Rods (i don't have the spec currently with me right now)
Eagle crank 95 mm (stroker kit by eagle to a 2.2L)
girdle
Scatter sheild
Electric Water pump
Toda oil pump gear
hytech hearder (insane nice job)
Cylinder head p&p by portflow
New vavle insert and guides by portflow
Skunk2 cams (Stage 3 they are degreed)
Skunk2 Vavle high compression
skunk2 vavle springs
skunk2 retainer
skunk2 cam gears
Skunk2 Manifold Honed (by http://www.theoldone.com)
JG throttle body
Golden eagle Titanium fuel rail
RC 440cc injectors
Aeromtive Fuel pressure Regulator A1000
walbro 255lph fuel pump and a Aeromitive fuel pump (haven't been touch)
the transmission is a type R tranny (for the street) i got a stock final udsm drive i beleive it's a 4.5, i got a 00 si i tranny for the strip i haven't used still waiting on my spool
with the 13x8 with spacer
I believe thats about it i haven't ran the motor yet on the track except when it was stock
Modified by Quitripin at 12:41 PM 10/23/2004
Modified by Quitripin at 3:04 PM 10/23/2004
Old Oct 23, 2004 | 12:09 PM
miller's Avatar
Default Re: 13 inch weld (Quitripin)
24.5"'s are probably what your looking for with your setup.
Old Oct 23, 2004 | 01:49 PM
jdm_ef9's Avatar
Default Re: 13 inch weld (miller)
whats the fd gonna be with the spool? i personally like 22's. my boy also runs 22's with a 4.70fd in a 85mm ls/vtec.
Old Oct 25, 2004 | 05:18 PM
Quitripin's Avatar
4.5 ( i believe thats stock#)
Old Oct 25, 2004 | 05:22 PM
99blackcivicSi's Avatar
i would say some 23's from m&h
Ekinchheng
Oct 4, 2014 03:55 PM
93egSLEEPER
May 13, 2010 07:31 PM
HondaH22a#1
Jan 19, 2009 04:30 PM
HondaH22a#1
Jan 19, 2009 12:39 PM
k-series
Nov 15, 2003 09:00 PM
