TPS for a JDM B16a OBD1 different from DC2, DA 90-01 integras?
Old Oct 21, 2004 | 06:49 PM
edo3276's Avatar
Default TPS resistance readings show that there are different TPS...Please post resistance readings here
I was just checking the total resistances of the throttle position sensors from a 92 integra GS and a 95 integra LS here are the measured resistance values
TPS act like variable resistors so here are the measurements:
95 LS integra - total resistance is approx 5.28 Kohms (5.2 Kohms, 82 ohms)
92 GS integra - total resistance is 4.83Kohms (4.5 Kohms, 320 ohms)
Any of you guys have a JDM B16a obd1 throttle body with the tps on or off, please post your resistance readings. I've been trying to figure out the difference between all types of TPS. With your help I'll hopefully be able to post a guide to helping everybody out with TPS adjustment without measing the voltages, just using resitances which would be more accurate.
Thanks guys.
Please bump for all to see.
Modified by edo3276 at 5:08 AM 10/22/2004
Old Oct 21, 2004 | 07:23 PM
boosted_dc2's Avatar
Default Re: TPS for a JDM B16a OBD1 different from DC2, DA 90-01 integras? (edo3276)
i was always told all honda tps's are the same
Landon
Old Oct 21, 2004 | 07:33 PM
edo3276's Avatar
Default Re: TPS for a JDM B16a OBD1 different from DC2, DA 90-01 integras? (boosted_dc2)
nope, from different resistance readings I've gotten they are obviously not all the same. Probably the reason why honda does not sell them just by themselves.
Please post your resistance readings from all pin combinations.
Old Oct 23, 2004 | 08:07 AM
perfecttiming's Avatar
all tps should read the same about .05v to 4.9v, .05v being at idel and 4.9v being w.o.t when testing them it should be consententle going up in value from idel to w.o.t
alscrx
Nov 15, 2008 12:17 PM
DRAGWORKS
10
Feb 3, 2006 06:20 PM
JibOnALib
Sep 14, 2005 09:47 PM
R_type
May 26, 2005 10:21 PM
ACURACY_VTEC
Mar 24, 2002 05:38 PM
