whining noise please help
Old Oct 21, 2004 | 06:47 PM
slipperyduck's Avatar
Default whining noise please help
so a couple of days ago my motor started making a whine on the pulley side. its a original d15 motor and the timing belt was replaced about 2 or 3 months ago. took off alt belt and ac belt and tried it and still i think the timing belt is rubbing something or something else.. is this a serious problem.. anybody know what it is
thanks
Old Oct 21, 2004 | 07:24 PM
drdisco69's Avatar
Default Re: whining noise please help (slipperyduck)
Doesn't sound like a good thing. Take off the timing belt covers and have a looksee, perhaps there's something obvious.
Old Oct 21, 2004 | 07:59 PM
Default Re: whining noise please help (drdisco69)
i already have the top one off and see everything is aight so i guess it something else .. im thinkin belt to tight anybody know anything thing else can the bottom cover b on wrong or something any help would be great
Old Oct 22, 2004 | 06:36 AM
bump>>>>>>>>>>>&g t;>>>>.
Old Oct 22, 2004 | 06:49 AM
crxY-49's Avatar
maybe the bearing on your timing belt tensioner is busted.
Old Oct 22, 2004 | 07:05 AM
Default Re: whining noise please help (crxY-49)
that aint good i guess it kind of sounds like a bearing it startes when i start the car and kind of whines and stops and goes if you know what i mean any more things i can do to fix it
Old Oct 22, 2004 | 08:36 AM
bump><.<><><>><>& lt;><><
Old Oct 22, 2004 | 08:42 AM
RC_SKUBY's Avatar
it sounds like your water pump is about to take a dump.
Old Oct 22, 2004 | 10:16 AM
spiceisler's Avatar
Default Re: whining noise please help (skuby_do)
Alternator?
Old Oct 22, 2004 | 10:18 AM
Default Re: whining noise please help (clean90Si)
naw took off ac and alt belt and started and still there all answers i got is front seal tensioner and water pump which is more likely to b the probelm
Old Oct 22, 2004 | 11:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skuby_do &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your water pump is about to take a dump. </TD></TR></TABLE>
ding ding ding!
Fix it quick...when that bearing locks up it will snap your timing belt. *speaks from experience*
Old Oct 22, 2004 | 11:33 AM
eumoria's Avatar
Default Re: whining noise please help (DaX)
Might be the alternator... I bought a new alternator and belt and it has a little squeal now. You should be able to locate where the sound is coming from. If it's behind that plastic get it fixed quick because like DAX said if something locks up in there it can cause a whole mess of trouble.
Old Oct 23, 2004 | 12:05 AM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slipperyduck &raquo;</TD></TR><TR><TD CLASS="quote">so a couple of days ago my motor started making a whine on the pulley side. its a original d15 motor and the timing belt was replaced about 2 or 3 months ago. took off alt belt and ac belt and tried it and still i think the timing belt is rubbing something or something else.. is this a serious problem.. anybody know what it is
thanks</TD></TR></TABLE>
mmaaaannn, you jinxed my car. I was readin this at work and when i went to start my **** up it was whining jsut like what you're talkinga bout.
definitely mine is coming from under the timing cover. I can feel the vibration on the cover itself.
GAY.
Psycho719
Sep 14, 2011 04:28 AM
vbolz
Apr 11, 2011 09:13 PM
Osis
Honda Civic (2001 - 2005)
Oct 15, 2007 08:23 AM
B_CRUZ!
Sep 9, 2003 12:20 PM
cbamishere
Feb 17, 2003 08:26 AM
