Apexi V-AFC on 00 GSR
This sounds like a really gay quesion but I wanted to know if the Apexi V-AFC will work on a 2000 GSR with OBDII version 2? Just I think I read some where it wil only work on obdII version 1.
its mainly because of the extra O2 sensor that the OBDII has. You can just buy an OBDI chip. Someone's selling one on eBay for $250.00. If you want one, you can just buy it and replace it. Easy and simple.
it will work just fine my best friend has a 1999 GSR which is OBDII just as yours is, but I do suggest that you buy a skunkII wiring harness so that you can switch your computer to OBDI as those react better to mods..
Definitely works. http://www.diabloautosports.com/prod...oducts_id=1321
