What does this relay do?
Old Oct 21, 2004 | 05:19 PM
baphomet's Avatar
Default What does this relay do?
It is in the drivers foot well kind of next to the pgmfi main relay. I can't seem to find it in the manual.
Its markings are:
Denso
056700-8570
12v
Made In Japan
Could it be causing all or some of my problems?
Old Oct 21, 2004 | 11:38 PM
7PSI CRX's Avatar
Default Re: What does this relay do? (devnull)
This one?
I doubt it has anything to do with your problems.
That's the starter relay.
If your car cranks, it's fine.
Old Oct 22, 2004 | 03:01 AM
NikoZai's Avatar
yeah i have a replacement if you need one. I thought mine was blown a while back so i got one from the junkyard.... then i tested the battery... and it was the battery =P
Old Oct 22, 2004 | 08:40 AM
baphomet's Avatar
Default Re: What does this relay do? (NikoZai)
I have the starter hooked up to a momentary switch because it won't crank from the ignition switch - maybe this relay is the cause.
Damn it - I was hoping it was the cause of the other issues too. oh well back to testing....
Old Oct 22, 2004 | 09:20 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Maybe that could be the cause of my starter problems. Ive replaced all the grounds and hot wires from the battery and it starts sometimes...but then other times it wont. Maybe the relay is sticking or something?
Anyway sorry i couldnt help you at all. Good luck on getting it fixed
Old Oct 22, 2004 | 04:41 PM
baphomet's Avatar
Default Re: What does this relay do? (sCeRaXn)
thanks, I need to find time to test the icu and main relay. If it isn't that or the ignition switch then I am completely stumped.
I guess I will have to do what I swore I would never do again - take it to a shop.
tvdc2
Audio / Security / Video
Jul 29, 2016 11:13 AM
wesk18
Dec 6, 2010 11:06 PM
SnlpeR
Oct 22, 2008 03:36 AM
SJR
Jan 28, 2005 12:50 PM
wambus
Feb 12, 2004 03:09 PM
