all motor stroke questions
Old Oct 21, 2004 | 08:29 AM
JBBNJ609's Avatar
Default all motor stroke questions
ive got a 84mm bore b18c1
i need a new crank, rods and pistons
i was lookin at buying an ls 89mm crank and getting custom rods and pistons
the rods part number is CRS5531A3DCA. the C-C is 5.531 http://www.eaglerod.com/produc....html
for this to work i need pistons with the pin location moved up .137" and up by the lowest oil ring . .
is this safe for daily driving HARD ?
will i have longevity issues ??
would it be better for me to just buy aftermarket gsr rods,crank and reg cp 84mm pistons ??
i want to stroke the motor as well as bore/sleeve it to 84mm but i dont want my rod ratio to drop any more then i have to because i want to be able to rev high with my skunk2 stage2 cams
Old Oct 21, 2004 | 01:14 PM
JBBNJ609's Avatar
Default Re: all motor stroke questions (jason bouchard)
BUMP
Old Oct 21, 2004 | 09:22 PM
JBBNJ609's Avatar
l also am looking at a 95mm crank but it lowers the rod ratio to 1.50
Old Oct 22, 2004 | 07:23 AM
JBBNJ609's Avatar
bump HELP AND INSIGHT PLEASE
Old Oct 22, 2004 | 08:48 AM
H22coupe's Avatar
Go check endynes site for pistons to run with those rods and the LS crank (I think those are the ones at least without checking). http://www.theoldone.com
Long rod combo
sh!ft
Nov 26, 2012 08:31 AM
prodragEG
Jun 8, 2008 08:54 PM
turbohatch101
Jan 5, 2008 01:42 PM
Baggy Spandex
Nov 1, 2005 12:02 PM
DEMNTD1
17
Oct 10, 2005 08:47 PM
