is it hard to go from a h22 swap and back to a b series swap?
Old Oct 20, 2004 | 08:29 PM
moreno's Avatar
Default is it hard to go from a h22 swap and back to a b series swap?
just wanted to know if i would run into any problems.
Old Oct 20, 2004 | 08:41 PM
hondaZvic's Avatar
Default Re: is it hard to go from a h22 swap and back to a b series swap? (moreno)
depends on what car.. civic im assuming, but what civic still matters. and on what you call hard....
change ur mounts back to stock. re-fit ur stock shifter to the floor after u have already cut a bigger hole in it.. re-wire ur car back to normal... pretty much gotta change back anything you modified.
Old Oct 21, 2004 | 02:13 AM
poison's Avatar
depends what mounts, how you mounted the prelude shifter, etc..
basically putting it back to the way it was before you modified it just like what hondaZvic said.
Old Oct 21, 2004 | 06:40 AM
v4lu3s's Avatar
RTFM
if you did it like me you would need ot weld on a new bracket ont eh passenger side frame rail, weld up the hole for the shifter cables and weld in the area around the old shifter as well.
Old Oct 21, 2004 | 12:24 PM
posjr's Avatar
Default Re: (v4lu3s)
I put a h22 in my da and there is no way that car will have a b-series again.
Old Oct 23, 2004 | 09:19 PM
. o 69 o .'s Avatar
Default Re: (posjr)
think you can mount a B-series on this again?
Maybe if you get creative with a welder
Old Oct 23, 2004 | 11:13 PM
b16hybridsol's Avatar
Default Re: (B16B)
its not hard to do, it just pisses you off because you feel like you are driving a dx ha. i drove my h22 teg around alot, then finally got my b16 sol out when school came around again, and it was very werid
Old Oct 23, 2004 | 11:15 PM
Default Re: (b16hybridsol)
then i read the post entirely haha. if you have the hasport mount kit learn how to weld. might have to weld in brackets for the shifter assembly if you cut alot out
Old Oct 24, 2004 | 08:12 AM
hondaZvic's Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">think you can mount a B-series on this again?
Maybe if you get creative with a welder</TD></TR></TABLE>
lol
B16EfMD
Mid-Atlantic (Sales)
Jan 25, 2013 09:09 PM
mikelaw420
Jun 16, 2010 02:09 PM
h22-cx-guy
Jun 30, 2004 11:40 PM
sol-racer
Mar 6, 2002 01:07 PM
