Help with coolant leaking inside my car.
Old Oct 20, 2004 | 06:27 PM
Hybrid2Be's Avatar
Default Help with coolant leaking inside my car.
What exactly causes this? I didn't have this problem until after the swap. A lot of you guys said if the brass holes are bent it will cause a leak inside the car.. Where is the coolant coming from if the hose on the other side of the fire wall is bent? How bent do the lines have to be to start leaking? I thought i fixed it and then 2 days later i have more coolant in the car. however, it's on the driver side now rather than the passanger. HELP!
Old Oct 20, 2004 | 06:29 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Help with coolant leaking inside my car. (Hybrid2Be)
Probably the heater core.
Old Oct 20, 2004 | 06:32 PM
bgoetz's Avatar
are you sure it is coolant and not brake fluid from the clutch master cylender??
Old Oct 20, 2004 | 06:33 PM
Hybrid2Be's Avatar
Default Re: Help with coolant leaking inside my car. (bgoetz)
positive it's coolant.. it's green..
anduhy
Nov 19, 2007 11:44 PM
BubLBack
Oct 5, 2006 09:47 PM
mdj_ge
Nov 23, 2004 05:13 PM
dunkd
Nov 13, 2003 07:28 AM
Blue teg
Dec 17, 2001 07:21 PM
