Does anyone know how to remove the rear inside panel?
Old Oct 20, 2004 | 05:17 PM
plutohk's Avatar
Default Does anyone know how to remove the rear inside panel?
Hi,
I try to replace the interior of my 95 prelude si from cloth to leather. I have got everything replaced except the padding on two rear panel. Can anyone shed some light on how to remove the rear inside panel so that I can take the padding out?
Thanks!
Old Oct 20, 2004 | 09:32 PM
ChrisRicketts's Avatar
Default Re: Does anyone know how to remove the rear inside panel? (plutohk)
i don't have a 4th gen, but i can probably tell you how to take out the rear panel. on my 5th gen it uses clips on the inside that pop into these fasteners. i just take a screwdriver and slip it in behind the panel and pop it out. be careful not to break the clips..........don't pull too hard or unevenly. there may or may not be other screws holding it in. just remove everything that is covering it, like the rear seat in my case, and find out what's holding it down. you'll figure it out.
Old Oct 21, 2004 | 11:15 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: Does anyone know how to remove the rear inside panel? (ChrisRicketts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">i don't pull too hard or unevenly. </TD></TR></TABLE>
I had to yank the ******* **** out of mine to get them out You have to pull sortof out and towards the steering wheel, it's hard to explain. Just keep yanking on them in different spots and you will eventually get it.
egeeb16
10
Jun 28, 2007 01:40 PM
taken roads
Honda Civic (2001 - 2005)
May 2, 2006 10:00 AM
in-n-outboy
Jan 26, 2006 05:58 PM
georgiajdm
Sep 19, 2003 10:15 AM
T_Rex
12
Jan 30, 2003 07:27 AM
