DIY Injection Molding anyone?
This topic has recently come to the surface while I've been thinking and working on one of my electronic projects. To have a piece made, the tooling alone is going to cost around $2000-$4000 which for an entreprenuer is not possible (at least not this one).
I did some searching online and haven't been able to come across anyone who's done the injection themselves. It requires that you have some specialized equipment, i do realize.
Anyone wana share their $0.02?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d@ve.G »</TD></TR><TR><TD CLASS="quote">What're you trying to make?</TD></TR></TABLE>
An electronic enclosure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">have you checked with emachineshop.com yet? I thought they were going to start doing injection molding. </TD></TR></TABLE>
Yea, their tooling is expensive also but more-so the program is just too poor to do what I want to do.
what are the given dimensions on this enclosure?
I'd get a block of plastic and mill it out to the dimensions then create a mold out of that? just a thought
Modified by S9i1R at 9:45 PM 10/20/2004
i make molds but for everything involved (core cav blocks, plates, pins, and material plus you have to have a press to operate it in$$$$) you would be better off milling out a chunck of plastic
unless your trying to mass produce this part
then i might be up for it
I'm working on a production piece that will be producted in low quantities.
I think my best bet is probably just going with an off-the-shelf piece after the research I've done. Spending $4000 to only ever make 100 parts is just not in my budjet LOL, especially when that's about 20% of the targeted RETAIL cost of the product. Worse yet I may only ever make 10-20, just depends on demand I guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedemon »</TD></TR><TR><TD CLASS="quote">i make molds but for everything involved (core cav blocks, plates, pins, and material plus you have to have a press to operate it in$$$$) you would be better off milling out a chunck of plastic
then i might be up for it </TD></TR></TABLE>
I would be interested to know more about this. I found a great enclosure but its still a little ancient looking. In order to have a competitive product in the automotive industry it really needs to look "neat."
then i might be up for it </TD></TR></TABLE>I would be interested to know more about this. I found a great enclosure but its still a little ancient looking. In order to have a competitive product in the automotive industry it really needs to look "neat."
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Look into LMB Heeger cases, they have a lot of choices, fairly cheap and they look terrific.
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D »</TD></TR><TR><TD CLASS="quote">Look into LMB Heeger cases, they have a lot of choices, fairly cheap and they look terrific.
stan</TD></TR></TABLE>
Awesome, i sure will. Thanks!!
I'm looking for something like this:
http://www.lmbheeger.com/catitems/plastic800_1.jpg
Except much much shorter, that one is 4..25" long. I would like something around 2.5" with the same overall design.
I'm going to keep looking, if anyone knows of anything please pass on the URL.
Thanks!
Thanks!
If you want a one-off piece maybe you should look into having it rapid-prototyped on an SLA or a 3-D printer. Here are a few.
http://www.thomasregister.com/...Guest
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">have you looked here?
http://www.pactecenclosures.com/</TD></TR></TABLE>
Yea they have some really neat handheld enclosures but they won't work for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brandon Clifton »</TD></TR><TR><TD CLASS="quote">If you want a one-off piece maybe you should look into having it rapid-prototyped on an SLA or a 3-D printer. Here are a few.
http://www.thomasregister.com/...Guest</TD></TR></TABLE>
Thanks, However I am in need of low quantities and they need to be very affordable. I'm thinking around $10 each in quantites of 100, no more than $20 though.
If doing DIY injection molding wasn't a project in and of itself I would definatly pursue it. I need to put it on my list of things to do (very long list might i add)
Thanks everyone
Thanks everyone
