Crankwork questions
Old Oct 20, 2004 | 12:59 PM
menkio's Avatar
Default Crankwork questions
I had my crank magnafluxed, polished jurnels, and de-burred. The oils on the crank are pretty big looking. They have a slanted oval around the hole, and each oppese each other at a 45 degree angle. Is that right, did my machine guy do good work. ?
also, cranks are freaking heavy as hell.. how much weight can i safly have removed/knife edged.
Old Oct 20, 2004 | 10:39 PM
menkio's Avatar
Default Re: Crankwork questions (yanta)
maybe adding an image would help.. lol
Old Oct 21, 2004 | 12:15 AM
Odiedogcx's Avatar
AIRBORNE
pics dont work lol
Old Oct 21, 2004 | 03:30 AM
MikeGRIS's Avatar
Default Re: Crankwork questions (Odiedogcx)
those slanted ovals on the mains are a good thing, from my understanding they help the oil easy into the bearing making start up easier. Knife edging a crank helps reduce windage in the oil pan, i think you can safely remove 1-2 lbs, and yes they are very heavy but removing 2lbs its a ton of material to remove from your crank, my machine shop guy said 300 bucks to knife edge and i would probably lose 1-2 lbs.
Old Oct 21, 2004 | 04:59 AM
IN VTEC's Avatar
It's called tear dropping. It's a form of chamfering the oil hole to smooth the flow of oil to the crank journals.
Old Oct 21, 2004 | 05:12 AM
menkio's Avatar
Default Re: Crankwork questions (IN VTEC)
any other opinions on knife edge work ? Also can someone recommend a good shop i can ship my head to for a valve job, nothing special, just new valve surface. 3 angle, stock honda angles.
Old Oct 21, 2004 | 10:04 AM
skunk2finatic's Avatar
Default Re: Crankwork questions (MikeGRIS)
he's rippin u off bro.. I got my crank work done for 100 bucks. chamfering, micropolish, and knife-edge work.
Old Oct 21, 2004 | 11:18 AM
MikeGRIS's Avatar
Default Re: Crankwork questions (skunk2finatic)
how much did you weight did you lose on your crank? 100 bucks sounds too good to be true
hi-Powered
May 16, 2006 01:32 PM
hybrid_vtec
Oct 4, 2004 11:48 AM
NERV
Sep 16, 2004 07:49 AM
AlLMoToRvOtEr
Sep 30, 2003 06:17 PM
nwarp
Aug 2, 2002 10:44 AM
