F*ck!! Now I have a leak in my crx!!
Old Oct 20, 2004 | 10:20 AM
EL Vap133's Avatar
Default F*ck!! Now I have a leak in my crx!!
Well after some heavy rain last night, I get into my crx and I notice that the passenger side floor is drenched. I have an 88 crx dx so I don't have a sunroof. I checked the car and only the passenger floor is wet, not even the seat or door panel. Yes I did have my windows all the way up, any ideas guys?
It has rained before and my crx has been fine, but last night was some pretty heavy rain!
EDIT: Found leak!!
Old Oct 20, 2004 | 10:27 AM
crx_88_si's Avatar
parked at an angle ??
could have drained in from the rear.
Old Oct 20, 2004 | 10:29 AM
dr_latino999's Avatar
Default Re: F*ck!! Now I have a leak in my crx!! (EL Vap133)
Bitch of a storm California had last night; any exposed holes in your firewall?
APEX CRX's Avatar
hmm. was the car parked even? or on a hill? One place I saw that leaked on my CRX sometimes is thru the speaker grille in the door trim panel. I parked at a 90 degree angle(perpindicular) to the curb and the driver side was facing downhill. The rain draining in the door off the glass was running down and hitting the inside of the passenger trim panel and coming thru the speaker grill.
Old Oct 20, 2004 | 10:37 AM
Burlyirishdude's Avatar
Default Re: F*ck!! Now I have a leak in my crx!! (APEX CRX)
Driving up California as much i did i ran into rain all the time. cept mine leaked on the driver side right newar the werid coin tray/relay is. The only thing i can think of....is the Vents in front of the Windshield somehow have opened or leaked or SOMETHING.....but i know what it's like to have to stuff a sock into the leak until the rain subsides or until get home from stockton to s.d and i can park my baby.....Check all the stripping by the windshield. That would be my only guess...Good luck guey
Old Oct 20, 2004 | 10:45 AM
EL Vap133's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">parked at an angle ??
could have drained in from the rear.</TD></TR></TABLE>
No sir, my car was in my flat driveway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Bitch of a storm California had last night; any exposed holes in your firewall?</TD></TR></TABLE>
Not that I can remember, but the car was parked and this is the first time it happened.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">hmm. was the car parked even? or on a hill? One place I saw that leaked on my CRX sometimes is thru the speaker grille in the door trim panel. I parked at a 90 degree angle(perpindicular) to the curb and the driver side was facing downhill. The rain draining in the door off the glass was running down and hitting the inside of the passenger trim panel and coming thru the speaker grill.</TD></TR></TABLE>
Parked in my flat driveway. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">Driving up California as much i did i ran into rain all the time. cept mine leaked on the driver side right newar the werid coin tray/relay is. The only thing i can think of....is the Vents in front of the Windshield somehow have opened or leaked or SOMETHING.....but i know what it's like to have to stuff a sock into the leak until the rain subsides or until get home from stockton to s.d and i can park my baby.....Check all the stripping by the windshield. That would be my only guess...Good luck guey </TD></TR></TABLE>
Thanks buey!
Old Oct 20, 2004 | 10:49 AM
CRX T-Si's Avatar
Default Re: (EL Vap133)
Gotta be the windsheild or the factory seam along the side of the car(black strip on the roof)
In my case it's the windsheild and the seam seal so i have a leak in the front windsheild and the rear hatch struct.
My solution, the car is covered with a tarp at all times at home till I am ready to use it.
Sucks.
Old Oct 20, 2004 | 10:59 AM
AllMotoRex's Avatar
Default Re: (CRX T-Si)
Mine has been doing the same thing , but mine leaks in my rear by the hatch window. I"m guessing its either the weather stripping or the winshield washer nozzle at top( its kinda loose i can move it slightly around).
Old Oct 20, 2004 | 11:06 AM
schwanginpt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Gotta be the windsheild or the factory seam along the side of the car(black strip on the roof)
Sucks.</TD></TR></TABLE>
i'm with him. if its just on that one side (and parked on level ground) i would say its the windshield. was anything else wet like up by the dash or anything?? something that would show the water trail.
sorry to hear that man.. good luck with it.
Old Oct 20, 2004 | 11:14 AM
EL Vap133's Avatar
Hmmm, I'll check that out, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schwanginpt &raquo;</TD></TR><TR><TD CLASS="quote">
sorry to hear that man.. good luck with it.</TD></TR></TABLE>
I did not notice anything else wet at all.
Old Oct 20, 2004 | 11:17 AM
ImprtTuner88's Avatar
but how do you fix the rear hatch strut leak problem?
Old Oct 20, 2004 | 11:19 AM
CRX Toad's Avatar
Ditto rain comes in through my speaker grill sometimes
Old Oct 20, 2004 | 11:20 AM
sprayedcrx's Avatar
check for a leak in the windshield molding it could have went right through
Old Oct 20, 2004 | 11:25 AM
EL Vap133's Avatar
Default Re: (ImprtTuner88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImprtTuner88 &raquo;</TD></TR><TR><TD CLASS="quote">but how do you fix the rear hatch strut leak problem?</TD></TR></TABLE>
Eh? I dunno, start your own thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprayedcrx &raquo;</TD></TR><TR><TD CLASS="quote">check for a leak in the windshield molding it could have went right through </TD></TR></TABLE>
Crap, I hope not, it's supposed to rain like crazy again tonight.
Old Oct 20, 2004 | 11:30 AM
Brownjd's Avatar
it's raining like hell here right now and my hatch is filling with water as we speak.
but anyways, prob that windshield EL Vap, good luck.
Old Oct 20, 2004 | 11:49 AM
EL Vap133's Avatar
Default Re: (Brownjd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd &raquo;</TD></TR><TR><TD CLASS="quote">it's raining like hell here right now and my hatch is filling with water as we speak.
but anyways, prob that windshield EL Vap, good luck.</TD></TR></TABLE>
Damn that sucks, well thanks and good luck to you too.
Old Oct 20, 2004 | 11:58 AM
jisu009's Avatar
Check your heater core too Just for good measure....
Old Oct 20, 2004 | 12:01 PM
t0eKnEe's Avatar
Its funny, when it rains here my passenger side floor gets soaked too. The seats are dry and so is the drivers side floor. Vap133, your not the only one with this prob
Old Oct 20, 2004 | 12:02 PM
Big Bang's Avatar
Default Re: (jisu009)
yeah i'd go with the windshield on that one. over in new negland we don't tend to have that problem because we can't keep on on the car that long with all the stones and stuff around here
Old Oct 20, 2004 | 12:12 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">Check your heater core too Just for good measure....</TD></TR></TABLE>
But would that get the passenger side floor wet and not anywhere on the console?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe &raquo;</TD></TR><TR><TD CLASS="quote">Its funny, when it rains here my passenger side floor gets soaked too. The seats are dry and so is the drivers side floor. Vap133, your not the only one with this prob </TD></TR></TABLE>
You too? How long have you had this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Converted &raquo;</TD></TR><TR><TD CLASS="quote">yeah i'd go with the windshield on that one. over in new negland we don't tend to have that problem because we can't keep on on the car that long with all the stones and stuff around here</TD></TR></TABLE>
So you replace windows a lot eh?
Old Oct 20, 2004 | 12:17 PM
ajcrx's Avatar
I had this problem, but my car was on jackstands while I was working on my front suspension and clutch. I noticed that it was coming down the inside of my firewall running under my ECU. No lie, I had about two inches of water on my passenger side only. So I said screw it and cut half my rug out because there was no way it would have dried out. It sucks not having a garage.
Old Oct 20, 2004 | 12:30 PM
t0eKnEe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
For as long as I had my car I would assume. I first noticed it when I pulled my passenger side floor mat and pulled the carpet to replacemt my ecu and noticed it was wet. Couple rainy days later I check that section again and its soaked, checked the drivers side and it was dry.
Old Oct 20, 2004 | 12:31 PM
CRX_Control's Avatar
Default Re: F*ck!! Now I have a leak in my crx!! (ajcrx)
hey, i get leaking trough my speakers cause my side view mirrors leak i guess, but they might be comming trough the speakers !(mine doesnt have speakers or the speaker guard thing)
EL Vap133's Avatar
Default Re: (t0eKnEe)
For as long as I had my car I would assume. I first noticed it when I pulled my passenger side floor mat and pulled the carpet to replacemt my ecu and noticed it was wet. Couple rainy days later I check that section again and its soaked, checked the drivers side and it was dry.</TD></TR></TABLE>
Oh wow, It just happened to me after all this rain last night.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajcrx &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem, but my car was on jackstands while I was working on my front suspension and clutch. I noticed that it was coming down the inside of my firewall running under my ECU. No lie, I had about two inches of water on my passenger side only. So I said screw it and cut half my rug out because there was no way it would have dried out. It sucks not having a garage.</TD></TR></TABLE>
Hmmm, from the firewall eh?
Old Oct 20, 2004 | 12:32 PM
EL Vap133's Avatar
Default Re: F*ck!! Now I have a leak in my crx!! (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">hey, i get leaking trough my speakers cause my side view mirrors leak i guess, but they might be comming trough the speakers !(mine doesnt have speakers or the speaker guard thing)</TD></TR></TABLE>
I don't think it's coming from the speakers on my car, I am pretty sure I would have noticed it.
