ZC Crank same as any other?
Old Oct 20, 2004 | 09:56 AM
91civichatch2571's Avatar
Default ZC Crank same as any other?
Im building my dohc zc and while i was taking it apart, I noticed that the crank is shot. One of the bearings spun a long time ago. Well, does anyone out there have an extra zc crank laying around or know of any others that will fit? Thanks
Old Oct 20, 2004 | 01:34 PM
Default Re: ZC Crank same as any other? (91civichatch2571)
Bump... I need to know this so bad
Old Oct 20, 2004 | 02:09 PM
julio_bOostamante's Avatar
I'm a Jackass
try using the 88-89 teg....look in the book for specs..might be the same.... not sure though ...
Old Oct 20, 2004 | 02:38 PM
mar778c's Avatar
Community Builder
Community Influencer
88-89 teg is correct.
Old Oct 20, 2004 | 03:03 PM
I'm a Jackass
Default Re: ZC Crank same as any other? (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">88-89 teg is correct. </TD></TR></TABLE>
sweet..one more brownie point for me!
Old Oct 20, 2004 | 06:00 PM
jlicrx's Avatar
Default Re: ZC Crank same as any other? (julio_bOostamante)
i believe you will find that the 88-89 integra crankshaft has a larger diameter snout on the front and you won't be able to get your ZC timing belt gear or pulley onto it - some D16A6 crankshafts will work if they have the right size snout - the A6 had 2 different sizes
Old Oct 20, 2004 | 09:04 PM
Default Re: ZC Crank same as any other? (jlicrx)
do you know what the right size is off the top of your head?
bokamper17
Oct 5, 2009 07:22 AM
9db85
Apr 2, 2007 11:39 AM
DarkSol97
Jul 8, 2006 02:36 PM
itslogics
12
Apr 29, 2005 11:56 AM
*Boostwerks*
14
Sep 26, 2002 04:29 PM
