Please help integra dash swap Speedo Hookup
Old Oct 20, 2004 | 08:24 AM
AIWFCIATR's Avatar
Default Please help integra dash swap Speedo Hookup
Does anyone know what color wire is the speed sensor on the integra dash? And what color is the speed sensor for the the civic? Thank you for the help!!!
Old Oct 20, 2004 | 08:28 AM
g2crx's Avatar
Default Re: Please help integra dash swap Speedo Hookup (AIWFCIATR)
run a cluster search i just put a gsr in my eg i'll try to find the link for ya found it try this
http://www.geocities.com/Area5....html
Old Oct 20, 2004 | 08:40 AM
g2crx's Avatar
Default Re: Please help integra dash swap Speedo Hookup (g2crx)
or try this
this is what i used to do mine, hope it helps.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Oct 20, 2004 | 09:45 AM
AIWFCIATR's Avatar
Bump... tried both I know the civic one is yellow and blue but what do I hook that up to on the integra wire harness for the speedometer to work?
Old Oct 20, 2004 | 11:40 AM
Solscud007's Avatar
merritr.com or something like that. I dont know if the EG is wired the same as an EK. so those might not work
Old Oct 24, 2004 | 02:51 AM
AIWFCIATR's Avatar
Default Re: Please help integra dash swap Speedo Hookup (Solscud007)
website doesnt work anyother websites? Thanks
Old Oct 24, 2004 | 05:45 AM
JT0220's Avatar
16-Pin Connector (B Connector)
Speedometer:
Integra Pin 6 - Blue/White
EG Civic Pin 2? - Yellow/Blue
Vehicle Speed Sensor:
Integra Pin 11 - Black/White
EG Civic Pin 3? - Black/Yellow
lsismore
Jan 13, 2006 01:14 AM
trooper0641
Apr 20, 2004 07:28 AM
dizzyroc88
14
Feb 29, 2004 11:44 AM
lazyguy
Aug 11, 2003 09:27 PM
DB8
Jun 10, 2002 07:53 PM
