High mileage LS rods in LS/Vtec...should I purchase new ones?
Old Oct 20, 2004 | 07:42 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default High mileage LS rods in LS/Vtec...should I purchase new ones?
I have a 95 LS block that has 125k on the internals that I'm using for LS/Vtec build. I'm concerned with the rods use and age. The block is at the machine shop waiting it's turn to be worked so I don't KNOW what shape they're in. Please give me your opinions and experiences if you have any. If you can, let me know the best place to pick some new ones up. Thanks in advance...
-Chris
Old Oct 20, 2004 | 08:55 AM
Default Re: High mileage LS rods in LS/Vtec...should I purchase new ones? (EK_TNR)
Come one guys...someone here has an idea right?
Old Oct 20, 2004 | 09:03 AM
RobbieG35's Avatar
12 Years Strong
You could try having the stock rods shotpeened or cryo-treated, but then again new rods are not very expensive
Old Oct 20, 2004 | 09:41 AM
Default Re: High mileage LS rods in LS/Vtec...should I purchase new ones? (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">You could try having the stock rods shotpeened or cryo-treated, but then again new rods are not very expensive</TD></TR></TABLE>
Do you know the best place to get them? I've searched and I'm not coming up with a answer. I had planned on getting them shot peened for the build originally. I wasn't sure if that was enough with the stress of 100k+ .
Thanks! Anyone else?
-Chris
Old Oct 20, 2004 | 09:58 AM
BigBodySmith's Avatar
a set of eagle rods with ARP rod bolts are like $300.00.
Old Oct 20, 2004 | 10:36 AM
Default Re: (BigBodySmith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBodySmith &raquo;</TD></TR><TR><TD CLASS="quote">a set of eagle rods with ARP rod bolts are like $300.00. </TD></TR></TABLE>
You are correct BBS...btw, markers worked out great! I had thought about that, but at the same time I wanted to run P30 pistons. I didn't want the expense of having to purchase new pistons...UNLESS you know of some pistons that aren't that expensive?
Thanks for the info, and thanks for the side markers! to a good seller!
-Chris
Old Oct 20, 2004 | 11:12 AM
ATS*EK24's Avatar
Fresh start for 09'
Default Re: (EK_TNR)
talk to jeff @import builders
he has some very pimp ultralite i-beam rods with arp hardware on it.
perfect for all motor set ups
Old Oct 20, 2004 | 06:54 PM
DonF's Avatar
Default Re: (JDMboy)
I would say change rods also, but as they are not press fit you will also need after-market pistons.
Nutzurchin
Northern California (Sales)
Jul 24, 2012 06:18 AM
SidmeisterEG
Mar 10, 2008 01:58 PM
CIVIC_3G
11
Mar 18, 2007 08:05 AM
