will 94 gsr springs fit a 95 ex coupe?
Old Oct 20, 2004 | 07:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default will 94 gsr springs fit a 95 ex coupe?
i am trying to do a budget drop on my ex and i have a set of gsr shocks and springs. i want to be able to put it back to stock by swapping out the stock springs and shocks if needed. will the shocks and tops cross over so all i have to do is get springs? thanks in advance.
Old Oct 20, 2004 | 07:45 AM
Patron's Avatar
It will physically fit in the strut, whether or not it's the spring rate and will function the same is another issue.
Old Oct 20, 2004 | 07:47 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (ptran13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 &raquo;</TD></TR><TR><TD CLASS="quote">It will physically fit in the strut, whether or not it's the spring rate and will function the same is another issue.</TD></TR></TABLE>
Bingo.
Integra rates are stiffer, which is cool, but it also won't drop the Civic as much...
Old Oct 20, 2004 | 08:13 AM
Mr. Badwrench
Default Re: (B18C5-EH2)
i am changing the springs with probably a 1.5 or 1.8 drop. i just dont want the hassle of having to swap everything over if i sell the car. i want to be able to swap assemblies. thanks for the replies.
Old Oct 20, 2004 | 08:37 AM
integraver's Avatar
Default Re: (boostedcivicsir)
plzz dont.. i did the same mistake.. my put the 94- up integra springs.. namely nuespeed.. on my 99 EK.. and blew my back shocks the first 4 miles ?
WHY ?
coz the first 5 coils on the springs are touching each other... so i would recommend that just stick with the springs that are designed and made for ur car and moreover i had and still have tiens now .. but i just wanted a drop that was more than the s tech so i installed them..
well the bright side of all this ? i wont be lazy anymore and WILL install the agx's that i bought 3 months back lol
Old Oct 20, 2004 | 09:22 AM
Mr. Badwrench
Default Re: (integraver)
i am using civic springs on integ shocks with teg tops. thats all.
Old Oct 20, 2004 | 09:34 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraver &raquo;</TD></TR><TR><TD CLASS="quote">plzz dont.. i did the same mistake.. my put the 94- up integra springs.. namely nuespeed.. on my 99 EK.. and blew my back shocks the first 4 miles ?
WHY ?
Ummm I don't see how having Integra springs on Civic dampers hurts anything unless the rates are WAY to stiff for the dampers.
Old Oct 20, 2004 | 10:26 AM
xkwzt21's Avatar
WHY ?
well the bright side of all this ? i wont be lazy anymore and WILL install the agx's that i bought 3 months back lol </TD></TR></TABLE>
i really dont see how those springs blew your shocks, something else had to be the culprit. people put stiffer springs on their stock shocks all the time and dont have any problems for hundreds if not thousands of miles. stock shocks were not necessarily made for aftermarket drop springs, that is why they make aftermarket shocks. stock shocks were valved to handle the stock springs, integra springs are not that much stiffer than civics
Old Oct 20, 2004 | 11:17 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: will 94 gsr springs fit a 95 ex coupe? (boostedcivicsir)
All the parts swap over fine. If anything, the car will be higher on the stock GSR springs/shocks. My car was pretty high, although not as high as stock, on stock ITR suspension. Handled pretty well, though.
Old Oct 20, 2004 | 03:16 PM
93CivicSI's Avatar
Yes, BUT, it will give you the 4 x 4 look....
Old Oct 20, 2004 | 03:18 PM
im a moron's Avatar
Default Re: will 94 gsr springs fit a 95 ex coupe? (93CivicSI)
i just thought the front would be a little higher because the motor weight ... but then again i could b wrong .
Old Oct 20, 2004 | 03:34 PM
qtiger's Avatar
It'll fit, no problems whatsoever.
Old Oct 20, 2004 | 03:42 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">Yes, BUT, it will give you the 4 x 4 look....</TD></TR></TABLE>
i got the yes/ no answer i was looking for.
i am putting civic drop springs on a spare suspension i have off of an integra gsr. i want to be able to put it back to stock fast if i decide to sell the car. i am not putting the teg springs i am doing a 1.5-1.8 drop. something to look a little better with the 15" heliums i got for free.
OG_brundle
Jan 7, 2010 02:11 PM
Jwbetley
Mar 24, 2005 02:28 PM
AZNBIGPIMPN505
Suspension & Brakes
11
Mar 2, 2005 01:52 PM
Confucius37
Dec 29, 2004 10:21 PM
xX86CRXsiXx
16
Mar 29, 2003 03:39 AM
