b16a compression
Old Oct 20, 2004 | 07:33 AM
Magick211's Avatar
Default b16a compression
The other day i tested a b16a for compression and it was
195 80 200 195
well i dont know what was up ok two days later i check it again and its good to go
195 195 200 195
Then i check it again today
195 195 200 195
Do you know why it could of read bad the first time i checked it? the motor was warmed up but had not been driven in a while
Old Oct 20, 2004 | 07:38 AM
V8SHME8's Avatar
Default Re: b16a compression (Magick211)
Compression gauge might not have had a good seal in the plug well.
Old Oct 20, 2004 | 08:10 AM
Magick211's Avatar
Default Re: b16a compression (V8SHME8)
Yeah i was thinking that but i pulled it out and put it back in but still could of had a bad seal
Old Oct 20, 2004 | 08:12 AM
crx_88_si's Avatar
cold motor?
Old Oct 20, 2004 | 11:33 AM
CRX T-Si's Avatar
Default Re: (crx_88_si)
Even if it's cold you would not get an 80psi......could ya??
for a B16 is kinda low. I got 190-195psi and I have 9:1 slugs.
Modified by CRX T-Si at 1:03 PM 10/20/2004
Old Oct 20, 2004 | 11:35 AM
Magick211's Avatar
Default Re: (CRX T-Si)
It only had low compression one time now when i test its good
B16A Hatchback
Aug 22, 2008 09:25 PM
theslugbug
Aug 14, 2004 03:58 PM
ef9b16
Dec 23, 2003 10:40 PM
b16acrxer
Oct 19, 2003 02:43 PM
