D16z6 and Nitrous?????
Old Oct 20, 2004 | 06:26 AM
EFz6er's Avatar
Default D16z6 and Nitrous?????
I just found out that the original owner of my civic had a shot of Nitrous on the D16z6. I stated before that the car feels slower than it should and I came to the conclusion that possibly the timing was retarded for the Nitrous. For those with a shot on your cars how much did you advance and/or retard your timing???
-John
Old Oct 20, 2004 | 06:51 AM
HumanResource's Avatar
Default Re: D16z6 and Nitrous????? (EFz6er)
For standard 50 shot I do 2-3 degrees retarded
But depending on what application the previous owner had it could be more
Get a TIming light to make sure.
Old Oct 20, 2004 | 06:54 AM
mrspeaker's Avatar
Friend I know with a 75shot retarded 2 degrees but uses a msd switch to retard.
and colder plugs..
U should try and find his phone number and/or get a timimg gun..
Old Oct 20, 2004 | 07:41 AM
EFz6er's Avatar
Default Re: D16z6 and Nitrous????? (Mrspeaker)
I am going to check to see if it has aftermarket cam gear...and if it is the stock one can the timing still be adjusted or are the aftermarket ones the only ones that can be adjusted???
Sorry if this is a dumb nOOb question Im just curious??
I would ask the prevous owner but he didnt do the swap it was the owner before him and he bought it way up north and sold it to me like 3 weeks after buying it
Old Oct 20, 2004 | 07:49 AM
mrspeaker's Avatar
If he had nitrous then im pretty sure he retarded the ignition timing..
retared ignition timing helps from detonation..
I dont think he would mess with the cam timing ..
But to set cam timing...
Turn the motor to Top dead center
Take the plugs out so u can turn the motor easily..(no compression)
There is an arrow on the cam gear that should be pointing up at TDC..
danmej1
16
Nov 16, 2009 06:41 PM
XzIpK
May 13, 2007 07:16 PM
Mr. Self Destruct
Mar 8, 2005 09:33 PM
cjnc22
May 25, 2004 01:51 PM
