Difference between FWD slicks and RWD slicks?
Old Oct 20, 2004 | 03:29 AM
TurboMiata's Avatar
Default Difference between FWD slicks and RWD slicks?
I cant really think of what would be different. I guess you could say "stickier on fwd to help offset the weight transfer" but then....why wouldnt you want super sticky on rwd too? Just makes it 60ft that much better.
Perhaps sidewall stiffness? I really cant think of what could be different between the two?
Old Oct 21, 2004 | 03:34 PM
Shongku's Avatar
Default Re: Difference between FWD slicks and RWD slicks? (TurboMiata)
Good question I'd like to know too
Old Oct 21, 2004 | 04:02 PM
PNG's Avatar
PNG
Default Re: Difference between FWD slicks and RWD slicks? (Shongku)
Well, theoretically, you'd want a stiffer sidewall or a tire that will still grip with higher inflation pressure to keep the car driveable at the top end of the track.
Old Oct 21, 2004 | 04:07 PM
saleensolution's Avatar
Default Re: Difference between FWD slicks and RWD slicks? (PNG)
who sells fornt wheel drive slicks? i never seen where they are sold different
Old Oct 22, 2004 | 12:20 AM
Shongku's Avatar
Default Re: Difference between FWD slicks and RWD slicks? (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution &raquo;</TD></TR><TR><TD CLASS="quote">who sells fornt wheel drive slicks? i never seen where they are sold different</TD></TR></TABLE>
Basically there is no such thing as a front wheel drive slicks right? I knew I was saying something wrong when I said this was a good question hehe becuz I already knew the answer. Because tires are tires, just get the right setup you need
in drag racing terms, the best balance you can get out of stickiness and size. (not to mention what he said above, sidewall strength or higher pressure slicks that stick to help with top end)
Edit: Unless he meant... front wheel drive slicks as in "slicks setup for front wheel drive" instead of saying that there's a specific application. Okay I feel dumb now, that musta been what he meant.
Old Oct 22, 2004 | 07:35 AM
bluebird's Avatar
the compound!!
Old Oct 22, 2004 | 09:17 AM
Default Re: Difference between FWD slicks and RWD slicks? (bluebird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird &raquo;</TD></TR><TR><TD CLASS="quote">the compound!!</TD></TR></TABLE>
the compouds are pretty much all the same there is very little difference between them all
Old Oct 22, 2004 | 12:23 PM
Rtype16's Avatar
When we were racing our Front wheel drive there were no such thing as a front wheel drive slick. We picked a compund we were happy with, a sidewall we were happy with and a size. Now adays there are slicks that were designed specifically for the front wheel drive cars. M/T, M&H, Goodyear and Dunlop hav all designed slicks that work better on front wheel drive vehicles through testing with FWD teams. Now you can also use these on RWD, but they probably wouldn't work as well as something else available.
Biggest things that differ are compound, sidewall strength and sizes.
Old Oct 22, 2004 | 01:17 PM
Default Re: Difference between FWD slicks and RWD slicks? (Rtype16)
i work for the a major tire campany that manufactures these tires (m/t and m&h) and there is no difference in the slicks. now m&h makes there slicks in a directional pattern for the way the plys are applied to the tire
Innes
Mar 14, 2012 06:59 AM
JakeSpec
Dec 2, 2010 09:29 PM
turbociv
Sep 12, 2005 03:52 AM
ZoRG
Oct 28, 2004 06:01 AM
typeRmini
May 20, 2004 02:47 PM
