Can change my manual gears when car is moving without clutch? !!
Old Oct 20, 2004 | 03:09 AM
shabasoft's Avatar
Default Can change my manual gears when car is moving without clutch? !!
I have a 94 2.2 vtec prelude with manual transmission.
I recently noticed when im driving i can change the gears without pressing down the clutch? what does this mean??
has my clutch gone, or do i need a new gear box?
thanks in advance..
Old Oct 20, 2004 | 03:38 AM
TimeRacer's Avatar
Default Re: Can change my manual gears when car is moving without clutch? !! (shabasoft)
Means nothing... All manual transmissions can do this. It's just like you didn't have any syncros at all. I can do a 3->4 shift without grinding and without using the clutch.
Old Oct 20, 2004 | 05:02 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Can change my manual gears when car is moving without clutch? !! (TimeRacer)
Yes it's normal. It's called power shifting.
Old Oct 20, 2004 | 05:20 AM
TimeRacer's Avatar
Default Re: Can change my manual gears when car is moving without clutch? !! (Sticky Tires)
Eh? I thought power shifting was using the clutch just not lifting your foot off the gas. You can't "power" shift very well w/o using the clutch as you need to unload the tranny (get off the gas and coast) to shift w/o the clutch to disengage the engine.
Old Oct 20, 2004 | 05:28 AM
* B A N N E D *
No that's called speed shifting. Power shifting is shifting without the clutch. There was a thread about this issue. There's always a mix up.
Old Oct 20, 2004 | 05:34 AM
* B A N N E D *
https://honda-tech.com/zerothread?id=419940
bg2128506
Acura TL, RL & ZDX
Jul 15, 2013 11:23 AM
Amuse9
Oct 13, 2009 03:13 PM
beandip
Honda S2000
35
Apr 15, 2006 03:06 PM
_Endless_
Sep 4, 2004 02:46 AM
highschooler
Jun 5, 2003 08:11 PM
