Toda D's or JUN 4's?
Hi there I am in the needs of a very powerfull cam for road racing. I have found that the very best options are this 2 cams (TODA D and JUN 4). I was wondering if anyone could give me some feed back or dyno sheets on both?
PS. Smartasses, do not tell me to seach around HONDA-TECH because I did and there is not much info on any of them....
I have been running Toda 'D's in my drag Civic for about 2 years now. I just put together a 2.1 liter B-series motor for the Civic and we dyno tuned with the Toda 'D's for hours. Then we swapped in some Skunk Stage 2's, and after only a couple of passes worth of tuning the Skunks were beating the 'D's pretty handily. No experience with the Jun 4's, so I can't speak to them. I think Tbone tested the Jun's , so he might have some useful info for you.
hello, the cam depends on the spec design of the motor you are building and type of fuel you are planning to use. I've had great results with Spec D cams and with JUN 3 cams (no exp with jun 4 .. tbone ???) ... in one motor the spec D's beat (peak and other parts of the curve) the jun 3s but in another motor opposite results.
although theoretically there is a difference in cam profile vs motor spec, I've seen it in actual real life motors that I build and dyno'd ... so like I said need some motor specs, not just which cams are better, etc.
I've also done cam mis-matching and gotten better results than any one manufacture.
Greg
Greg
http://www.importreview.com
They have a couple dyno comparisons between Toda Ds (deez nutz) and Skunk2s, just click on the performance link and check it out.
Turbo R
20
Dec 18, 2004 01:37 PM
Maddox
19
Jan 23, 2004 06:18 AM
TEGPOWER44
Jul 7, 2002 12:47 PM
Pinhead
Apr 6, 2002 02:37 PM
