91 RS - Veers violently at high speed, tugs at low speed???
My 300,000mi 1991 Acura Integra RS, orig. B18A1 & manual trans is SICK, no I mean ILL... I've done major maint as needed: tuneups, brakes, timing belt, axles, wheel bearings, bushings, springs, struts, etc. But now it's got a steering/suspension/drivetrain problem I can't find - nor can the Acura experts.
At 85 on the hwy - it suddenly veered VIOLENTLY to the right - with no warning - then came back under control. Very brief, violent pull. Got over - Looked it over - brake disc looked fine, nothing broken, nothing loose... Limped along the access at 10, then 20... eventually I was testing 60-80 w/no problems. That weekend I tore open the right suspension, drivetrain, steering & brakes looking for damage. Nada. Didn't reoccur for about a month.
This time, At 20mph, it felt wobbly, and the wheel briefly tugged hard to the right. Again, I inspected; even did a brake job (turned, pads, repl. orig. calipers). Nada. Finally, I turned it over to my local independent Acura repair shop.
They suggested the steering rack - which I'd considered. Rack was original & on my "to-do" list, so I had them replace it. Long & short - Rack is great, but an hour later, same wobbly, tugging to right problem.
This time, they took it for a longer test drive & recreated the problem - called it "wierd". But definitely the transmission. I agreed - everything else in the drive train has been looked at! They tore down the trans & found NOTHING. Zip. They inspected the CVs & intermediate shaft - nothing amiss.
Frustrated, they too gave up - pronounced drivetrain healthy & didn't charge me for the teardown (though I had them do the clutch since the trans was out - charged me parts only - they did note scarring on the flywheel before turning it). These guys do NOTHING but Honda & Acura, and they're stumped.
So - I've got it back & I'm piece by piece trying to isolate the problem.
Removed (new) front calipers & sealed the lines - test drove w/back brakes only - same problem...
Removed the knuckle - rebuilt it - new bearing, new hub... Same problem.
Axle is next, though shop said it looked fine (I replaced w/new about 80k ago)
One thing I've isolated - problem is torque sensitive - under acceleration, no problem, let up & coast - it may, may not happen, but it is ALWAYS coasting or under very little power when it feels wobbly & tugs. Suggests CV but not clunking/ticking. Differential?????
I'm going to try axle swap w/a used part just to see if it affects it - though 4 sets of eyes have inspected the joints already.
Any suggestions? Perhaps no damage in trans, but at 300k, differential lash or other critical clearances way out of spec?
brockscivic
Jul 30, 2006 02:33 PM
