Big fuel leak ...Need help ASAP!!
I was replacing the fuel filter and installing the fuel pressure gauge but when I reinstall the fuel line and the bolt it leaks BIG time!! it leak right on the spot I mark in RED. The fuel squirt out like the drawing....anybody know what's going on here?? Help me out please. TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">sounds like you cracked the line, you need to replace it.
Landon</TD></TR></TABLE>
Is it hard?? which part do I need??
I was thinking...it was really hard to loosen that bolt up. I might of kink or crush the fuel line near the filter.
Dont tell that its going to be expensive to repair/replace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Its easy to repair just get the line. </TD></TR></TABLE>
what is the part #??
is it a long line all the way to the fuel tank?? or is it a short line that I can replace myself??
Help me ..I have to park my car for tomorrow...I might not have ride for work!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">never mind, I got the part #
thanks Luserkid
its the feedline from the tank isnt it?? it doesnt go to the fuelrail right?? if so it is a BPITA to change.
Landon
thanks Luserkid
</TD></TR></TABLE>its the feedline from the tank isnt it?? it doesnt go to the fuelrail right?? if so it is a BPITA to change.
Landon
the line that goes to the fuel filter.
Not the fuelrail.
Not the fuelrail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">does it go all the way to the fuel tank in the back??
I hoping it dont.</TD></TR></TABLE>
yup
u could try cutting it off and reflaring it
yup
Follow the line, if it looks like it goes under the car then your kind of screwed. If it cuts off then you might be in luck. Cant really tell by that pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black cx »</TD></TR><TR><TD CLASS="quote">Did you put in the washers and used a flared nut wrench? Trying moving the filter while screwing the bolt in</TD></TR></TABLE>
I thought this bolt dont have washer inside, right?? cus my dont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Follow the line, if it looks like it goes under the car then your kind of screwed. If it cuts off then you might be in luck. Cant really tell by that pic. </TD></TR></TABLE>
I look earlier from under the hood or engine bay, it look like it dont have any cut or adaptor/connections.
Oh well,...I guess I'll find out at the H-part dealer tomorrow.
you can cut off that line at the tip and get it flaired, using a brake flare kit.
I would just take off the nut then put some liquid teflon tape around the thread area and seat of the line install it then wait a few hours and see if it holds.
up pa and away
to the top
have anyone done this...
could it be that I overtighten it??
another question...when bolting the line in, do I push it in or let it loose then tighten the bolt??
to the tophave anyone done this...
Why couldnt you just ghetto it for now with cuttint it and using a rubber hose and 2 worm camps?
1. Cut yours down a few inches, go to the parts store and buy a new hard line for like 5.00 then get like 2" or the rubber hose and clamp it.
2. see if the parts store will let you use their flairing tool and just redo it.
3. you would still need the flair tool but cut it down get a new short hard line and a female 2 female box and do it that way. You could even get a 3 way splitter or "T" and put you fuel gauge on the "T"
1 would be easiest and would relly not be ghetto becuse it for sure would hold the pressure that a fuel pump would push out. Replacing the whole line would be a pain in the ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">up pa and away
to the top
another question...when I bolingt the line in, do I push it in or let it loose then tighten the bolt??
You can take it off and try some teflon tape or if its comming out the back not on the threads then its not tight enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cappa »</TD></TR><TR><TD CLASS="quote">
You can take it off and try some teflon tape or if its comming out the back not on the threads then its not tight enough.</TD></TR></TABLE>
I try the teflon tape on the tread but the thing is it leak from the line where the bolt seats on. If you look at the pic again, the RED drawing shows where the fuel is leaking.
I'd think it could be that the line was over tightned.
If it is cracked I wouldn't 1/2 *** it.
Fuel lines are not something to rig up.
If you need to replace the line when you get to the part of putting that nut back on maybe use some teflon tape and go hand tight and then maybe a 1/4 turn to assure that it's tight and then test and see if that will be okay.
