Ek B18c Swap auto to manual
Old Oct 19, 2004 | 07:39 PM
lude6r's Avatar
Default Ek B18c Swap auto to manual
I have an ek and I am getting a b18c. My car is automatic right now what mounts do I need to convert it over?
Old Oct 20, 2004 | 12:41 PM
95excoupe's Avatar
Default Re: Ek B18c Swap auto to manual (lude6r)
Bump for a friend...we searched and couldnt find anything specific about mounts for an ek when your car is auto and you are doing a B18 swap. Thanks
Old Oct 20, 2004 | 05:28 PM
rhetorical's Avatar
I think the tranny mounts are the same, I've got an '88 CRX that I had to have the mounts cut and rewelded though.
Old Oct 20, 2004 | 05:58 PM
95excoupe's Avatar
Default Re: (rhetorical)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhetorical &raquo;</TD></TR><TR><TD CLASS="quote"> I think the tranny mounts are the same, I've got an '88 CRX that I had to have the mounts cut and rewelded though.</TD></TR></TABLE>
Yeah that would help if he had an 88 crx what about a 96 CIVIC?
Old Oct 21, 2004 | 08:33 PM
95excoupe's Avatar
Default Re: (95excoupe)
Come on I know someone has done this before
Old Oct 21, 2004 | 08:59 PM
ek99's Avatar
I've done it to my 99 coupe. Its the same as doing a 5 speed. All the mounts will fit. Just like a regular swap, you have to use the 99-00 si rear tranny mount, top tranny mount and on the timing belt side, you also have to use the si engine mount with the stock civic or si bracket that bolts on to the mount. The rest, you could use from the b18c. You also have to cut a hole where the shift linkage shifter is going to go because the hole that's on the car right now for the auto shifter is too short and too small. Plus you also have to add all the other stuff like pedals, clutch cylinder, clutch lines, etc. Let me know if you have any other questions.
Old Oct 22, 2004 | 11:43 AM
95excoupe's Avatar
Default Re: (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 &raquo;</TD></TR><TR><TD CLASS="quote">I've done it to my 99 coupe. Its the same as doing a 5 speed. All the mounts will fit. Just like a regular swap, you have to use the 99-00 si rear tranny mount, top tranny mount and on the timing belt side, you also have to use the si engine mount with the stock civic or si bracket that bolts on to the mount. The rest, you could use from the b18c. You also have to cut a hole where the shift linkage shifter is going to go because the hole that's on the car right now for the auto shifter is too short and too small. Plus you also have to add all the other stuff like pedals, clutch cylinder, clutch lines, etc. Let me know if you have any other questions.</TD></TR></TABLE>
Exactly what I needed, Thanks!
esurds
Jul 9, 2009 05:50 PM
95civiccpdx
12
Aug 23, 2007 09:28 AM
99TurboBlue
Jul 9, 2007 05:07 AM
endlessdv
Feb 26, 2005 07:53 AM
Snipes69
Nov 3, 2002 08:31 PM
