B18C Gsr Build Up question
Old Oct 19, 2004 | 05:38 PM
eg6hatch's Avatar
Default B18C Gsr Build Up question
I am almost done with my gsr head, and its been off for about 3 months, through out the rebuild, what im wondeirng is, i want to have the mating surface of the head shaved for sealing reasons, but at the same time i want to raise compression, what would be a good amount to shave off, without taking any chances. thanks alot
Old Oct 19, 2004 | 05:53 PM
chad's Avatar
Moderator
Default Re: B18C Gsr Build Up question (eg6hatch)
depends on:
cams
pistons
valves
piston to valve clearance is the main issue
Old Oct 22, 2004 | 12:14 PM
eg6hatch's Avatar
ITR cams, Factory valves, factory pistons
Old Oct 22, 2004 | 12:44 PM
Turbo E's Avatar
id say look for a thin HG instead of milling the head. that way you can go back to normal compression if you need to.
JDMCRX
Jul 22, 2009 05:59 PM
TYPErCRX
Jul 15, 2006 01:03 PM
DC2SIR-G
15
Mar 30, 2006 11:20 PM
craka
Jan 27, 2003 05:01 PM
Mr. Softee
Aug 21, 2001 12:55 PM
