what do i need to built a b20b/lsvtec...to get good hp and high rpm ???
Old Oct 19, 2004 | 05:27 PM
wilntegra's Avatar
Default what do i need to built a b20b/lsvtec...to get good hp and high rpm ???
got a 98 gsr head and a 01 b20b block looking 4 suggestions....thanks pls reply..
and also what tranny sould i use....??...and does it fit on a 91 teg??
Old Oct 20, 2004 | 05:21 PM
99lsvtecauto's Avatar
Default Re: what do i need to built a b20b/lsvtec...to get good hp and high rpm ??? (wilntegra)
most if not all bseries trannies will fit in a 91 teg. U building an all motor car or a boost car . what are u trying 2 achieve . this a street car or track ***** . we need 2 know more 2 help others might not b so willing 2 help and flame u my lsvtec is being finished now . u need 2 replace everything that wears block wise.
Old Oct 20, 2004 | 05:38 PM
LSvtec03's Avatar
Default Re: what do i need to built a b20b/lsvtec...to get good hp and high rpm ??? (99lsvtecauto)
https://honda-tech.com/zerothread?id=501372
use a gsr, b16, or type r tranny.
and search.
Old Oct 22, 2004 | 12:22 PM
silversly's Avatar
BANNED
Default Re: what do i need to built a b20b/lsvtec...to get good hp and high rpm ??? (LSvtec03)
dont go b20 b20 is a pos. it is an ls block with a big bore. and an ls block is around 150 while a b20 block is around 600 just get an ls block and get iron sleeves if you race a b20 block with stock sleeves the sleeves will give out
Old Oct 22, 2004 | 01:30 PM
Default Re: what do i need to built a b20b/lsvtec...to get good hp and high rpm ??? (ml2Vo)
he is correct
Old Oct 22, 2004 | 02:30 PM
silversly's Avatar
BANNED
i have a 1.8 ls block with b16 pistons with a stock gsr head with no bolts i hit 13.2 with a stock clutch in a 92 SIon 14' inch baby slicks my friend with a b20/v stock block ect. in a lighter DX eg shell hit the same exact time so...b20? no b20
Robs94gsr
Jan 12, 2010 05:04 PM
JDM KID 510
10
Jan 29, 2006 06:14 AM
sickb16b
Jul 25, 2005 07:08 AM
matman4444
Jun 13, 2004 12:10 AM
Boostless97Lude
Nov 20, 2002 07:19 PM
