one o2 sensor on b16a with zdyne one wire conversion...Confusion need help!
Old Oct 19, 2004 | 05:08 PM
asiansgoweeee's Avatar
Default one o2 sensor on b16a with zdyne one wire conversion...Confusion need help!
i am wanting to replace my o2 sensor and i looked at oxygensensors.com and found one for a 94 del sol vtec and the universal sensor has 4 wires. i took a look at the one o2 sensor in my car that is located right on top of the header near the end ( i have jdm itr header) and it only has one wire (i think its green or blue). Will this universal sensor work and what do i do with the extra 3? please help i need to see if this stops the stuttering. thanks.
Old Oct 19, 2004 | 05:24 PM
ACRProject's Avatar
Default Re: one o2 sensor on b16a with zdyne one wire conversion...Confusion need help! (asiansgoweeee)
the 4 wire o2 off a del sol vtec will not work unless you converted your car to obd1. If you are look for the right o2 sensor. Get a singe wire o2 off a 88 - 91 crx/civic.
Old Oct 19, 2004 | 05:27 PM
drdisco69's Avatar
What ecu are you using to run the car?
Old Oct 19, 2004 | 06:20 PM
Default Re: one o2 sensor on b16a with zdyne one wire conversion...Confusion need help! (drdisco69)
zdyne
Old Oct 19, 2004 | 06:22 PM
Default Re: one o2 sensor on b16a with zdyne one wire conversion...Confusion need help! (ACRProject)
ok so any o2 sensor off a 88-91 crx/civic should work for the b16a right? just making sure and appreciate it.
1Down 5Up
Engine Management and Tuning
Aug 9, 2017 09:08 AM
rage4theused
20
Jun 9, 2014 04:20 PM
astroxtc
Dec 13, 2006 12:57 PM
delux247
Jan 27, 2004 04:14 AM
