JDM dc header and USDM dc header?!?!?
Old Oct 19, 2004 | 04:26 PM
Mike Ockhurts's Avatar
Default JDM dc header and USDM dc header?!?!?
is the only difference between them the 2.5 the collecter size? or are the ports on the runners from the JDM header bigger? TIA
Old Oct 19, 2004 | 10:58 PM
Default Re: JDM dc header and USDM dc header?!?!? (cx Son)
anyone have an answer?
Old Oct 19, 2004 | 11:34 PM
blackdelslo's Avatar
the jdm one has a 2.5" collector
Old Oct 20, 2004 | 05:00 PM
Default Re: JDM dc header and USDM dc header?!?!? (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">the jdm one has a 2.5" collector</TD></TR></TABLE>
yea, but anyhting else besides that? mainly the runners?
Old Oct 20, 2004 | 05:51 PM
MrMike's Avatar
i always thought that the jdm header had larger primares, but i dunno
Old Oct 20, 2004 | 06:09 PM
Copy Cat's Avatar
Default Re: JDM dc header and USDM dc header?!?!? (MrMike)
the DC Sports JDM 4-1 has lower cost, larger primaries, lack of inner welds at the flange, and better collector. The only benefit about the JDM ITR header is that it has better ground clearance and a heat shield.
Old Oct 20, 2004 | 06:37 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM dc header and USDM dc header?!?!? (CivicFerioViRs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioViRs &raquo;</TD></TR><TR><TD CLASS="quote">the DC Sports JDM 4-1 has lower cost, larger primaries, lack of inner welds at the flange, and better collector. The only benefit about the JDM ITR header is that it has better ground clearance and a heat shield. </TD></TR></TABLE>
He's referring to the "JDM" and "USDM" versions of the DC Sports headers. When comparing the two (assuming they're both ITR versions), the primaries are the same diameter, it's just the collector that's larger.
By the way, why does your above post look so familiar...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">From a performance and value perspective, the DC Sports JDM 4-1 has the edge with it's slightly lower cost, larger primaries, lack of inner welds at the flange, and better collector.</TD></TR></TABLE>
At least someone's been paying attention to my posts.
Old Oct 20, 2004 | 09:35 PM
anyone else have a clue? im referring to the 4-1 header BTW
Old Oct 20, 2004 | 10:21 PM
ilovemyhonda's Avatar
Old Oct 20, 2004 | 10:37 PM
1750cc's Avatar
i think it has larger primaries too...
does it matter a lot if the collector is only 2.25" instead of the 2.5"? applciation is on b16a
Old Oct 21, 2004 | 03:58 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cx Son &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have a clue? im referring to the 4-1 header BTW</TD></TR></TABLE>
What additional information are you looking for. The collector on the JDM version is 2.5" vs. 2.0" on the USDM versions. As I said, the tubing itself is the same size for both versions (if they're both ITR headers).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cx Son &raquo;</TD></TR><TR><TD CLASS="quote">i think it has larger primaries too...
does it matter a lot if the collector is only 2.25" <FONT COLOR="red">(USDM is 2.0", not 2.25")</FONT> instead of the 2.5"? applciation is on b16a
If you're comparing a USDM DC 4-1 made for the B16A application to the DC JDM 4-1, then the information I've read indicates that the tubing size of the primaries on the B16A header is a bit smaller. And yes, the JDM version will perform quite a bit better than the USDM version.
DailyDrivenDB8
Sep 2, 2008 09:34 PM
Mike Ockhurts
Oct 19, 2004 10:58 PM
Del Souless
13
Sep 25, 2004 01:34 PM
98ITR#0020
Sep 9, 2004 05:39 PM
typeRSXS
Feb 8, 2004 10:07 PM
