who makes 5point harness racing seats?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord »</TD></TR><TR><TD CLASS="quote">first off.......why do you want seats made for harnesses?</TD></TR></TABLE>
cause my track requires them if you run 11's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 »</TD></TR><TR><TD CLASS="quote">Do you run 11s?</TD></TR></TABLE>
obviously
and 5 pt... does it have to have the 5th hole near the crotch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verticle »</TD></TR><TR><TD CLASS="quote">
obviously
and 5 pt... does it have to have the 5th hole near the crotch?</TD></TR></TABLE>
There is no obviously about it, you ***. We have no idea what is done to his car, or anything.
obviously
OK I may be wrong but dosen't a 5 point just connect to the floor and crunch your nuts if you fly forward and prevent you from slipping out from under the harness and has nothing to do with the seat. I say Find yourself a nice 6 point... gotta look out for your boys!
O yeah... lets see this car!!!
Modified by ITRiWISH at 10:59 PM 10/19/2004
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRiWISH »</TD></TR><TR><TD CLASS="quote">OK I may be wrong but dosen't a 5 point just connect to the floor and crunch your nuts if you fly forward and prevent you from slipping out from under the harness and has nothing to do with the seat. I say Find yourself a nice 6 point... gotta look out for your boys!
Modified by ITRiWISH at 10:59 PM 10/19/2004</TD></TR></TABLE>
well where can i get a 6point then?
i will take pics when it is out of my friends garage. he's in the middle of building it for me.
its a civic eg b18c1
endyn rollerwave 9.0:1cr pistons
crower rods
rs sleeved block 1.9lt 83mm
aebs head studs
supertech valvetrain
p&p head
endyn breather kit
t4 .68ar p-trim, 60-1 .70ar TO4s turbo
sfp race turbo manifold
tial 38mm wastegate
tial 50mm bov
pte 600hp intercooler
pte 750cc injectors
turboxs hp dual stage boost controller
hondata es200
hondata boost upgrade w/3bar map
yes
crower rods
aebs head studs
p&p head
endyn breather kit
tial 38mm wastegate
tial 50mm bov
pte 750cc injectors
hondata es200
i dont have enough experience to do it myself. and my friend has the exact same set up and runs 10.5@141 w/28pis boost 620whp 420wtq
i will be running what ever amount of boost to get into the low 11's.
But if someone else drives his car to the 11's... He'll be glad us folks on Honda-tech told him where he could get a good 5-point harness.
Catch my point?
After a quick search I found this: http://www.import-performance-....html
Catch my point?
i had no problem getting a 12.4 w. 315whp so w/500+whp i think low 11's sound reasonable.
i have a question though, is there more than racing than getting a good launch and shifting when you need to? if there is let me know. im not trying to be sacastic either, i just here people say that alot. and wondering if theres somethin i wasnt informed about.
Modified by egb18c1 at 10:30 PM 10/19/2004
For the most part, a good launch, knowing when to make shifts, and shifting are the main things that the driver can do to make his ET Lower. However the key to racing is obviously Practice.
Good luck with your project, sounds like a winner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pawwalski »</TD></TR><TR><TD CLASS="quote">But if someone else drives his car to the 11's... He'll be glad us folks on Honda-tech told him where he could get a good 5-point harness.
Catch my point?</TD></TR></TABLE>
Well, first off, he didn't ask for a 5 point harness. And I already told him a brand of seat that can be used with a five point.
any racing seat with holes for the shoulder straps can be used for a 5 or 6 point harness. I think the only place I have seen something similar is on a go-kart.
and haven't seen a 6 point harness go here, they are sweet!
http://www.curpiermotorsport.c....html
