one eyed monster....my civic
this started about a week ago...and now its really starting to annoy(sp) the **** out of me...my passenger side headlight would turn off....and then turn back on...at random...i think sumthing is lose...cus wen i hit it...it would come back on...did any1 else have this problem?...whats the best way to permenatly fixing it...im gettin tired of pulling over and hitting my headlights... thanks
Guest
Posts: n/a
I have the same exact problem which both at times. The problem with mine was I had strong headlight bulbs and the heat off of them melted the plugs causing them to get all fucked up and not staying in place.
Just pull the plugs from your headlights out and check to see if the actual plug has any damage to it, that could be your problem.
Good Luck!
Good Luck!
I have the same problem. The connectors that attach to the bulb are all corroded and nasty. You can try cleaning them, but it'd be better to replace them. They can't be more than $5 or so from a local parts store.
Don'tKnoKnuthin
Sep 13, 2013 08:35 AM
