car keep dying(94 teg distributor on 93 teg)
Old Oct 19, 2004 | 03:00 PM
alfee's Avatar
Default car keep dying(94 teg distributor on 93 teg)
ok i've got a few problems. my buddy's 93 teg distributor isn't working no more so he put a 94 on. the car starts but when the car sits in neutral and you gas it, the motor just shuts off and blow black smoke from the throtal. but if its in gear then you can drive it if you gas it a bit. anyone know whats wrong? is the distributor wrong or something? PLEASE HELP!
Old Oct 19, 2004 | 03:07 PM
alfee's Avatar
Default Re: car keep dying(94 teg distributor on 93 teg) (alfee)
HELLLLLLLLLLLP! we're fixin' in the rain!!!!!
Old Oct 19, 2004 | 03:21 PM
B_CRUZ!'s Avatar
94 dist on 93 integ should work fine... unless the replacement dist. is bad.
they are both OBD1. did you check the timing?
Old Oct 19, 2004 | 03:23 PM
alfee's Avatar
Default Re: car keep dying(94 teg distributor on 93 teg) (b_cruz)
havent checked timing, no gun to do so. could that pose the only problem?
Old Oct 19, 2004 | 03:26 PM
B_CRUZ!'s Avatar
could be... just make sure it isn't all the way retarded or advanced.
Old Oct 19, 2004 | 03:31 PM
alfee's Avatar
yea, while the car is in idle, i slowly shifted the dizzy up n down to where the car would stay alive. but still the car dies if you gas it in neutral. ???
Old Oct 19, 2004 | 03:40 PM
B_CRUZ!'s Avatar
like I said, maybe the replacement one is bad.
1badcrx
Jun 6, 2009 05:01 PM
BAL1ST1KREX925
Northern California (Sales)
Apr 1, 2008 02:19 PM
