I Need Help
Last night I found out that the block I bought is an AT block, my car is a MT. I bought a new flywheel and clutch kit, and new flywheel bolts. The AT block still has the (possibly?) torque converter disc on it, and I was thinking I can just remove that and slap on the new flywheel. Is this right?
Any help is appreciated. Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgentegracer »</TD></TR><TR><TD CLASS="quote">... The AT block still has the (possibly?) torque converter disc on it, and I was thinking I can just remove that and slap on the new flywheel. Is this right?</TD></TR></TABLE>Yes. (That thing is called a flex plate.) It's good that you got bolts, because the MT flywheel bolts are longer than the AT flexplate bolts...
Thanks, I had to get new ones no matter what. The old ones got chewed by a spring that came loose, and hit them when I shifted. Again thanks for clarification.
street_ride14
Sep 2, 2008 02:46 PM
f150harleytruck7
Feb 7, 2006 09:55 AM
PatrickGSR94
Apr 18, 2003 06:00 AM
